View Full Version : Miscellaneous Konica Minolta , print Booklet (Center Staple&Fold ) on A4 paper
pinspin
01-07-2017, 01:41 PM
Hello! I try to set print Booklet (Center Staple&Fold ) from PC according
https://www.youtube.com/watch?v=bwemJ8LkspE .
With A3 paper it work properly . But when i use A4 paper , sheets get on the upper tray of finisher without Staple&Fold .
Additionally , if I put original on the feeder of the copier and do COPY Booklet (Center Staple&Fold ) on A4 paper - it work properly ! How to print Booklet on A4 paper ? Thanks
Synthohol
01-07-2017, 02:29 PM
any settings in the application window can cancel out options in the driver window.
only set finishing options and layout in the driver and ignore the application box.
pinspin
01-07-2017, 02:54 PM
Synthohol (http://www.copytechnet.com/forums/members/synthohol.html) , thanks for the answer ! How i may to disable the application box ?
Synthohol
01-08-2017, 05:25 AM
what model do you have so i can be more specific?
pinspin
01-08-2017, 05:38 AM
bizhub c360
Synthohol
01-08-2017, 06:44 AM
in the first 2 pics are the settings id use except id probably select a tray.
the last one is the "application dialog box" which i leave default.
Word was the application in this instance, adobe should be similar.
just leave the first window alone that pops up when you hit print, go right to printer preferences.
pinspin
01-10-2017, 03:09 PM
Synthohol (http://www.copytechnet.com/forums/members/synthohol.html) ! Thank you ! Done. + I made copier initialization .
