Synthohol
01-09-2017, 08:45 PM
USB Backup/Copy Function
Applied Machines: C224e-C754e, 224e-754e
Starting with Firmware version C8 (released Feb 12, 2014) the applied machines can backup, restore, and copy Address Book, Network Settings, User Settings, Authentication Data, Remote Access Settings, and Administrator Settings. Excellent alternative to Pagescope Data Administrator for field technicians due to the fact it does not require use of a laptop and more simple process. Security Settings in Pagescope Web Connection will not be copied through this procedure.
1. Prerequisites
o USB thumb drive
o Correct MFP model with C8 Firmware Loaded or newer.
Saving data to USB Drive
1. Verify Machine Firmware in Service Mode is at least C8 and set Software Switch 72 to Hex 04. Service Mode>System 2>Software Switch Settings>Switch No.=72 Hex Assingment=04>Fix>End>Exit>Reboot Machine
2. Plug USB into Side Port of MFP
3. Administrator Mode>2nd Page>External Memory Backup>Export
4. Select desired items you wish to backup>Password>Create a password and input it twice>Start
5. Select Close. Selected Data is now saved on USB drive. Files are saved as a .DAT file so you cannot read/edit them.
6. To transfer settings to a new MFP or apply it to machine from which it was saved follow steps 1 and 2 again.
7. Administrator Mode>2nd page>External Memory Backup>Import
8. Enter Password you created for Backup in step 4>Start
9. Upon completion of Import a results screen will be displayed showing which items were successfully imported from USB
10. Hit Close and you will be pro
1. Prerequisites
o USB thumb drive
