View Full Version : BH C3110 disable replace imaging unit message
copier tech
01-24-2017, 05:30 PM
Hi all,
Is it possible to clear this message without replacing the IU chip or replacing the IU?
On the C35 there was a bulletin that with a FW upgrade showed how to extend the life of the IU's to 167% which worked great.
I have a C3110 that is printing perfectly but asking for the cyan IU to be replaced.
Jonny
09-13-2017, 11:58 PM
Its in service mode you can extend the yields as you said.
Its under "IU Yields Settings" change from Standard to Extension
This should give you 167 %
allan
09-14-2017, 04:01 AM
You can get the reset chips.
Synthohol
09-14-2017, 05:10 AM
for reference...
http://www.copytechnet.com/forums/attachments/konica-minolta/37621d1505362212-bh-c3110-disable-replace-imaging-unit-message-iuld-jpg
Harjan
02-02-2018, 11:19 AM
Hi,
Where is the chip of the drum? I can't find it.
The drum lifetime is 25.000 and then hes stops with printing.
I was wonder if the chip can be removed and then can be printing further?
Tanks.
copier tech
11-17-2020, 05:42 PM
for reference...
I'm replying to my old post here, but this machine has the colour image units all showing 0% life remaining however its not showing a warning & is printing fine.
I found this setting in CE mode (see pic below) with this enabled will the machine NEVER ask for the IU to be replaced!?
47339
copyman
11-17-2020, 10:51 PM
47339
Don't have many of the small bizhubs and always use the extend life feature but have never seen that screen in pic before. Haven't seen a 3110 but have a few C35's & C3100P's. Will check and see if I can find that setting on these models. Might be it's only on the newer C3110 and why I haven't seen it?
srvctec
11-18-2020, 05:37 PM
We have a bunch of these POS machines and I've never seen that setting. Wonder what the exact path to that setting is.
copier tech
11-18-2020, 06:06 PM
I totally agree such a POS model.
I updated the firmware & after was scrolling through the CE menu & found that option.
Toxic
11-18-2020, 07:38 PM
Also never see this option before.
Maybe FW version you put is the key, if you share that info? :)
copier tech
11-18-2020, 07:48 PM
I've just checked the CE manual & this option is there!
47351
srvctec
11-18-2020, 07:52 PM
47351
But that is only for simultaneous replacement of all IUs, not the actual reminding of needing a new IU.
copier tech
11-18-2020, 08:49 PM
Ah yes! ok I should have read my own post!
Still not sure why all the image units show 0% remaining but no message.
srvctec
11-18-2020, 08:58 PM
Me neither and I'd like to know how to make that happen since the print/copy quality is usually still fine when IUs reach zero percent.
tsbservice
11-18-2020, 09:00 PM
They're life extended that's why.
copier tech
11-18-2020, 09:03 PM
OK I understand that life extend will stretch them out to 167% but how can I tell what life they have done below 0% so like when they get to - 67%
srvctec
I thought when the life extended thing was performed, it still kept the percentage in relation to the actual life left, not go past 0% but I probably got that wrong. That's what happens when you have CRS.
Toxic
11-18-2020, 09:26 PM
I dont have much expirience with A4 mfps but if i remember good from c25/35, if IU life is extended it drop to 0% then rest -67% still show 0% till life end.
I am not sure about this.
tsbservice
11-18-2020, 09:41 PM
They likely will fail with image quality defects way before machine stops. Tell the customers that at zero IU life you cannot guarantee image quality or prepare yourself with IUs.
