View Full Version : pinting problem on ineo +454e
jakani
01-25-2017, 03:51 PM
hello ,
i have a problem when printing and copying i get a faded line in the middle of the paper
i changed the drum , the transfer belt and the fusing unit
i initialized the counter and did image stabilization still the same problem !
here is a copy of the counter :
35363
any suggestion on how to solve this would be appreciated
thank you very much
kingarthur
01-25-2017, 04:03 PM
I can't open the attachment, but a faded line is normally the printhead needs cleaning
jakani
01-25-2017, 04:14 PM
thank you for replying
i attached it again
35366
i don't think this printer has a printhead !
kingarthur
01-25-2017, 04:31 PM
i attached it again
35366
I would think it has! I'd get a trained engineer to look at it !!
jakani
01-25-2017, 04:49 PM
thank you for replying kingarthur
i just searched the manual for the printhead i could not find it !
thank you very much again , if i could not solve this may be i consult with an other company or something getting an engineer is not an option i don't know one !
copier addict
01-25-2017, 05:11 PM
If you aren't going to take the advice seriously, why bother asking. kingarthur gave you very good advice (this machine indeed does have a printhead).
jakani
01-25-2017, 05:14 PM
of course i take his advice seriously and i really appreciate it
Woxner
01-25-2017, 06:35 PM
take that placstic wand and read the easy instructions on cleaning the laser glass. if its called a printhead or laser who gives a crap it does the same thing.....
if that dont work look at the dev unit. its good for 590 k may have something in it
jakani
01-26-2017, 03:54 PM
i was not able to find it at first because in the manual it called PH unit ,
i cleaned it and the printer worked as it should , thank you very much for fast replying to direct solution
REGSIS
01-26-2017, 05:02 PM
PH=printhead ;)
Laser printhead, LED printhead, ink printhead; every printer (or MFP) has a printhead!
