View Full Version : Jamming Bizhub 754 feeding trays 3 and 4 at the same time
Rikk811
01-25-2017, 04:40 PM
Hey all!
First time poster on this site.
I'm working on a Konica Minolta Bizhub 754 and have been having issues with tray 4. It would try and feed multiple pages, even if I try to make one copy. Tray 4 would also feed when I print/copy from tray 3.
I've already replaced the whole tray 4 feed assembly, hoping that that had an issue. Maybe the clutch for tray 4?
Any help would be appreciated
Brett GS
01-25-2017, 07:31 PM
Hi
Take both tray 3 and 4 out and off their rails and check there is no small piece of paper stuck in the plugs if that makes sense.
I have had this issue and after a while i done what it said above and found a small piece of paper that was caysing the plug to not have proper connection with the machines connector.
Good luck,hope this helps.
Brett
Rikk811
01-26-2017, 07:15 AM
Hi
Brett
Thanks!
I looked for paper behind the trays, one of the first things i did. Didn't find any.
Placed a ticket with Konica, they suggested replacing the PRCB. We'll see how that goes when it comes in.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Rikk811
02-14-2017, 03:11 PM
Replaced PRCB-no help. Ordered MFPB, will see if that solves it
blackcat4866
02-14-2017, 08:34 PM
I can't really believe this thread has progressed to a PRCB, without discussion of the exact jam code. =^..^=
femaster
02-14-2017, 10:24 PM
Wow, slow down a bit there! Board this, board that, feed unit this, have we done any basic troubleshooting yet? By your description, it sounds like the feed clutch on tray 4 is permanently engaged. Does tray 3 work fine (single and multiple pages) if you leave tray 4 pulled out? Yes? Pull the wire off the feed clutch in tray 4, push tray in. Does tray 3 still work properly in that configuration?
Reattach feed clutch wire, pull out tray 3, test tray 4; can you run single or multiple pages from tray 4?
On a side note of paper being stuck in the electrical connector in the copier, did you verify also there was no paper stuck on the connector on the tray?
Let us know what the jams codes are, if any, when you run the above tests, and what test you were running at the time you got the code.
Sent from Tapatalk.
Synthohol
02-14-2017, 10:43 PM
try isolating (unset) the trays 1 at a time.
if still feeds both there is something locked up.
also wouldn't be surprised if a zip-tie is causing it.
Rikk811
02-15-2017, 06:18 PM
To clarify, I wasn't using this thread as my only means of information, and apologize for not providing all of the info. I work for a dealer that is Konica Minolta Pro Tech Certified, so we have an abundance of info from the manufacturer. However, I did not find anything relevant in their KnowledgeBase, or with other techs that I work with.
I keep getting a J14-01 (misfeed from tray 4). Tray 4 wants to feed multiple pages when only instructed for one. This happens when tray 3 is being used as well, tray 4 feeds at the same time.
I've already inspected both trays for foreign objects, as stated above, replaced tray 4 feed assembly (so that ruled out cluthes/gears related to that).
After doing this, I reached out to Konica Minolta themselves, and after explaining what has already been done, THEY recommended replacing the PRCB. After that did not solve it, THEY recommended to replace the MFPB. I'm abut to replace that now, if that doesn't resolve the issue, they want to replace the SSD. We will see how it goes.
Thanks for the info.
Rikk811
02-15-2017, 06:24 PM
Forgot to mention, if I pull tray 4 out, or disable it, tray 3 runs flawless. So it all has to do with tray 4. I think Konica Minolta didn't think about the board that controls trays 3 and 4. There may be some issues with that.
There has not been any trouble coded, just the jam from tray 4 and tray 3, if tray 4 is set
blackcat4866
02-15-2017, 07:01 PM
This might sound silly to you, but I would spend some time tracing down the wire harness between the pickup clutches at tray #3 & #4, and the MFPB. During all this disassembly/re-assembly a wire providing ground to one of these clutches may have been pinched to frame. Since most copiers are ground switching and the 24vdc is always present to the clutch, the moment the machine boots up, one of these clutches may be engaged. When the feed motor turns on, that clutch will feed paper, whether the MFPB signals it to or not. It's got a ground, so it will feed.
copyman
02-15-2017, 08:03 PM
Exactly my thoughts blackcat. And exactly why I avoid calling K/M tech support. Always a bad board with them.
femaster
02-16-2017, 01:10 AM
I concur, do a continuity check on the ground side of the clutch in tray 4 to find out if it's permanently grounded.
EarthKmTech
02-16-2017, 11:25 AM
Prcb does not directly control the trays on this engine, the paper feed driver board does. (PWB-KH) and communicates to the PRCB by a flat cable. I have had this fault before where the tray continues to pickup additional sheets on a single page job after the first sheet is fed and then the machine stops with a jam detected at pickup, on this engine and the previous 652 series. It was this board in this instance. (PWB-KH)
Gift
02-16-2017, 11:38 AM
Rikk811
02-27-2017, 07:39 PM
Sorry for the delay all! And thank you for the feedback!
The problem has been resolved!!! It ended up being the paper feed drive board. When speaking to the agent at Konica, they said that they were looking at the manual and this machine didn't have that board, that's why they suggested the PRCB. I didn't even think to argue with him, and I didn't look at the service manual for it myself like i should've. But all is good to go now, and I know for the next time!
Thanks all!
blackcat4866
02-27-2017, 08:01 PM
Congratulations on your success, and thanks for posting back your results. =^..^=
richwalker
08-31-2018, 05:58 PM
Good day EarthKMTech,
Thanks for this post as I have been going back and forth with a C654e with the same issue. The customer is way out of town and its a government office that is always printing. I have ordered the board and will inform on completion.
Richwalker.
