View Full Version : Konica minolta bizhub 601 can't print with front cassettes only bypass or LU
noulaja
02-11-2017, 08:12 AM
Good day,
I have a problem with a KMBH 601, the machine can't print with the front cassette only bypass and large cassette unit (LU) are working. I change the motor in the rear side but no change.
Please, waiting your help
xeclectron
02-11-2017, 03:49 PM
Does it recognise the cassettes on the control panel?
Sent from my SM-T805 using Tapatalk
noulaja
02-12-2017, 08:30 AM
Yes the machine recognize the cassettes on the control panel.
xeclectron
02-12-2017, 11:21 AM
Why was the motor replaced? Will the machine copy from the cassettes? If so, maybe connect a laptop/USB to the machine and see if it will print that way...To eliminate a customer print driver error.
Or do the cassettes not work under any circumstances?
noulaja
02-12-2017, 11:42 PM
The motor change was DC Brushress Motor 40 for Bizhub 600 601 750 751 . Part number =
15AA80050.I change it because when you put the paper and close the cassette, motor was not running to bring the paper up. After changing the motor, the problem remain. It is why i think that the problem is not motor.
