View Full Version : Konica c253 see 2451 code after replacing fuse on transfer belt
We have a Konica c253 that came up with the code after my boss change the fuse and the transfer belt unit. Just found out she used a Slow blow fuse could that be the problem does it need to be a fast blow fuse really appreciate any help as I am sick this week and cannot go look at it and she is attempting to do it herself. The hardware store called and said they have a hundred amp fast blow fuse instead of the 80 that is needed would that work if the problem is that she used a slow Blow instead of fast blow or is 100 amp too big
allan
02-16-2017, 05:15 PM
If it was anything else except a 63mA slow blow fuse it could cause problems.
Hope you get well soon.
myster
02-16-2017, 05:16 PM
You need an 80m fuse for fast blow. .
Sometimes the machine does not burn it at first and skips the error. Try several times;)
allan
02-16-2017, 05:23 PM
I can't respond to that.... not as clever as the Japanese designers that installs the slow blow fuses.
