kmtechsjj11
02-16-2017, 10:17 PM
Bizhub c454e, machine will print fine from the emperon controller with KM driver
When attempting to print from fiery driver - jobs hang and machine eventually codes out with C-FD30.
"ASIC second sheet DMA00 time out " ...
steps taken, replaced MFP HDD (although printing through the engine works fine, do not believe its an MFP issue personally)
• MFP board (MFPB) - replaced
• DSC board/1 (DSCB/1) - shouldnt be it
• DSC board/2 (DSCB/2) - shouldnt be it
• EFI relay board
(EFIRYB: VI-506) -replaced
• Dual scan image
processing board
(DSIPB) - shouldnt have anything to do with it
also the VI cable for the fiery has been replaced.
Also the fiery system code was reflashed --seemed to work for a day before crashing again.
ive replaced/reinstalled the fiery driver, tried creating new ports, restarting spooler, flashing mfp firmware, etc.
any ideas?
kmtechsjj11
02-28-2017, 09:53 PM
swapped the HDD on the fiery, reflashed system code 1.2 ... still same issue-
unable to print a config page /any "Print Pages" through the fiery engine - unable to print through fiery driver without blue flashing lights, eventual crash C-FD30.
Synthohol
02-28-2017, 10:19 PM
have you replaced the ram on the mfp board yet?
should be setup LPR port 515 queue name Print
have you tried running the diagnostics?
maybe the results will help narrow it down.
is the marketing area set correctly?
Related Products:bizhub 224e,bizhub 284e,bizhub 364e,bizhub 454e,bizhub 554e,bizhub 654,bizhub 654e,bizhub 754,bizhub 754e,bizhub C224e,bizhub C284e,bizhub C364e,bizhub C454e,bizhub C554e,bizhub C654e,bizhub C754e
Related Options:
Reference
The Self Diagnostic function conducts diagnosis for faulty memory and various boards in the main body when a trouble code is generated or main body activation failure occurs. The area of concern will not pass the diagnostic test (NG).
Prerequisites
Please install the latest firmware.
Procedure (using SERVICE MODE menu)
1. Call the Service Mode to the screen.
2. Touch these keys in this order: [State Confirmation] g [Self-diagnostic] g [Check All].
3. Press the Start key to start the check procedure.
4. When the check procedure is completed, the results are shown on the screen. If any of the check results are NG, take measures upon confirmation of the corruption details mentioned above and Next action.
Note: Press the Stop key to interrupt the check sequence.
Procedure (using main power switch)
1. Open the front door.
2. Turn the main power switch ON while pressing the power key.After a short beep sound is made once, release the power key and close the front door. Wait to display the self diagnosis (full check) screen.
3. After displaying the self diagnosis screen, press the start key. The self diagnosis (full check) is started. The result of the diagnosis is displayed for every item. (OK/NG)
4. After finishing the diagnosis for all items, turn the main power switch OFF.
5. If there is an item displaying NG, investigate the NG item and take countermeasures.
Individual Diagnostic Checks
Check mode
Check details
Corruption details
Next Action
DIMM R/W Check
• Execute Read/Write Check for DIMM on the MFP board.
• Execute the same check as [Rough Check] under [Memory/HDD Adj.] ->
[Memory Check].
• DIMM on the MFP board
• Corruption of CPU
• Reseat DIMM.
• Check the connectors on the MFP board.
On Board Memory Check
R/W Check
Execute Read/Write Check for On Board Memory on the MFP board.
• Corruption of On Board Memory on the MFP board
• Corruption of battery
Replace the MFP board.
Pattern Check
Execute Read Check for the pattern ready written in the area secured in On Board Memory on the MFP board for Read.
• The pattern data for test cannot be read because the pattern data for test has been rewritten, or a contact failure of the electrical parts
occurred.
• The correct information cannot be read because the data in the area for Read has been modified due to
software failure, or a failure of the electrical parts occurred.
SSD Check
R/W Check
Execute Read/Write for the SSD board
• Connection failure of the SATAI/F
connector of the SSD board
• Corruption of SSD device
• Corruption of MFP board
• Reseat the SSD board.
• Replace the SSD board.
• Replace the MFP board.
Pattern Check
Execute Read Check for the pattern ready written in the area secured in SSD.
occurred.
• The correct information cannot be read because the data in the area for Read has been modified due to software failure, or a failure of the electrical parts occurred.
HDD Check
R/W Check
Execute Read/Write for HDD.
• HDD cable failure
• HDD failure
• MFP board failure
• Check the HDD cable
connection.
• Replace the HDD cable.
• Replace HDD.
Self-diagnostic
(I/F Check)
Check whether the communications between HDD and MFP are normal.
Evaluate OK if there is any response returned from HDD, and NG if there is no response.
Check the HDD cable connection.
Self-diagnostic
(Memory Check)
Execute the buffer test and the media test.
• Buffer test
Execute Read/Write Test for the buffer memory of HDD. Transfer the data by DMA to check whether the buffer
memory works normally.
• Media test
Execute Read/Write Test for the disks of HDD. Check whether the disks, motor, and head works normally. Use the reserved area for the test.
Retrieve the test log, and display existence of error.
Replace HDD.
Compress/Decompression Check
?MFP Board
Execute the compression/extension test for the MFP board.
Corruption of the compressed/ extended circuits or memory of MFP.
DS Board
Execute the compression/extension test for the DS board.
Corruption of the compressed/ extended circuits or memory of MFP board.
• Remove and insert the DS board.
• Replace the DS board.
Fiery I/F Board
Execute the compression/extension test for the Fiery I/F board.
• Connection failure of the fiery I/F board connector.
• Corruption of the compressed/ extended circuits or memory of Fiery I/F board.
• Remove and insert the Fiery I/F board.
• Replace the Fiery I/F board.
Memory Bus Check
?Input Image Bus Check (CCD)
Execute the input image bus test for the MFP board.
• Connection failure of the CCD I/F connector.
• Corruption of the input image circuit or image bus of MFP board.
• Check the connections.
• Replace the CCD cable.
Input Image Bus Check (CIS)
Execute the input image bus test for the DS board.
• Connection failure of the DS board I/F connector.
• Corruption of the input image circuit or image bus of DS board.
• Replace the DF cable.
• Replace DF.
Output Image Bus Check
FAX Board Check
• Execute the FAX board test.
• Execute the data transmission sound test.
• Connection failure of the cables connected to the FAX board.
• Failure of the FAX board.
• Replace the FAX signal cable.
• Replace the FAX power supply cable.
• Replace the FAX board.
LAN check
Execute the Ping test.
• The network is faulty.
• Corruption of the LAN connector of the MFP board.
• Connection failure of the LAN cable due to breakage of the claw.
• Correct the network of the unit.
• Replace the LAN cable.
USB check
Execute the test to check whether the USB board operates normally.
• Connection failure of the USB connector of the MFP board.
• Connection failure of the USB device.
• Replace each USB device (authentication device, etc.).
Note: For additional detail please refer to the Adjustment/Setting section of the Service Manual g 12. Service Mode g 12.18.12 Self-diagnostic.
