View Full Version : Konica C364 Scan to email
mearmi
02-17-2017, 01:13 PM
Konica Minolta C364 doesn't scan to email
Failed Job with "Server Connection Error"
Please advise thanks
Synthohol
02-17-2017, 01:28 PM
thats entirely too vague.
what SMTP server/settings?
if gmail or office365 you need special firmware as the non-e machines dont support the new security protocols.
please elaborate.
mearmi
02-18-2017, 04:48 AM
please elaborate.
Thanks a lot for your reply. Client is using 2 Copiers (C284e and C364). Both are using Gmail. C284e is scanning but 364 doesn't.
If firmware? Can you please send me . Thanks and Regards,
Gift
02-20-2017, 01:40 PM
This Office365 confuses me - I have a customer using a C451 and C454e - guess wich machine causing no trouble? It's the totally outdated C451 working flawless while the C454e does cause intermittent server connection issues. Tried latest FW and bulletins, fixed network speed and even swapping the network connection between both MFPs wich didn't change anything. I also don't understand why the error isn't reproduceable all the time - it's also not dependent on how much pages I need to scan.
rrrohan
02-20-2017, 02:38 PM
Try setting gmail to "allow less secure apps"
Reed
02-20-2017, 05:11 PM
Is the firmware updated on the C364 to G00-72 ? It won't scan to email if it's not updated. I had the same problem with a C284. Once I updated the firmware it worked. Gmail updated their security settings and without the updated firmware the machine won't scan. There is a bulletin about the firmware and scanning issue.
copier tech
02-20-2017, 06:02 PM
He's using office365!
Reed
02-20-2017, 06:16 PM
I couldn't it to scan to email at all without updated firmware. It didn't matter which email it was authenticating through whether it be gmail, Office 365, yahoo, or the local internet provider. If the firmware isn't updated I suggest trying that first. It will drive you crazy.. trust me.
rrrohan
02-21-2017, 01:04 AM
when did he tell you that?
Synthohol
02-21-2017, 01:58 AM
not the OP.
mearmi
02-21-2017, 04:58 AM
Yes we updated G00-72. It didn't work.
Can you please send me the firmware.
Thanks and Regards,
Reed
02-21-2017, 06:10 AM
there are also 2 smaller firmware patches you have install first.
rrrohan
02-21-2017, 12:15 PM
can the OP please confirm what mail sever your using with details such as what port, encryption (if any), if authentication is req or off
if its gmail i use the not SSL server address and enable "allow less ecure apps"
depending on the mail server using your ISP mail server might be a option
Konicatech
02-22-2017, 04:51 PM
As has already been stated, you need to update the firmware first (firmware effectively makes it an 'e' machine).
Once done, you need to make the following settings:
1. Login to your GMAIL account and turn on 'Less secure apps' - If this is not turned on, then it simply will not work!
2. Set mail server address to smtp.gmail.com, choose start TLS, and set to port 465
3. Turn on authentication, and input your @gmail.com address as the username and put your password in.
You also need to have the device email address set etc to match the gmail account.
