View Full Version : Miscellaneous konica minolta bizhub 185 after changed developer and drum
tfxro
02-20-2017, 01:45 PM
After I changed developer and drum and tcr adjust,machine is working about 20 pages.
After that blank copy is just like that(image).
I change corona, i change transfer roller, cleanig blade and same problems.
What happens?
35680
rrrohan
02-20-2017, 01:56 PM
Did you rebuild the drum or changed the entire assy?
tonerspot
02-20-2017, 02:31 PM
check developer roller, you have too fat "brush" on one side.
tfxro
02-20-2017, 04:13 PM
I rebuild the drum
tfxro
02-20-2017, 04:15 PM
I check but is uniform .
katlyn
03-06-2017, 10:14 PM
Are you sure you don't forget anything, some contacts? Is it the proper drum ?
service_man
03-27-2017, 08:39 AM
If you put the drum maybe KATUN, you have that problem.
I have the problem on bh 215, when I put new drum Katun, and I get that copie.
Put back old drum, and machine is working fine.
Regards
