View Full Version : TASKalfa 2052ci Envelope Feeding
EDSNOW
02-26-2017, 04:57 PM
Greetings all.
I haven't had a lot of requests for feeding envelopes in the new series products.
I understand that envelopes can feed from the bypass as well as the cassettes according to the operation guide.
Any feedback would be appreciated as I have a new installation coming up with a 2552ci and internal finisher.
I do have one 4052ci in the field with a internal finisher but have not checked out envelope feeding.
I remember back in the day that the earlier Kyocera products would feed and sometimes wrinkle or smear the envelopes but the only feed option
back then was the bypass.
Any input greatly appreciated.
Ed Snow
Whitehorse, Yukon
Has Been
02-26-2017, 05:58 PM
Greetings all.
Ed Snow
Whitehorse, Yukon
Dear Customers,
Copiers will not do labels or envelopes.
Thank you for your business.
EDSNOW
02-26-2017, 06:30 PM
Sorry to hear that copiers do not do envelopes or labels.
Perhaps someone else may care to weigh in on this topic.
Thank You
Ed
Luther
02-26-2017, 07:02 PM
We have had no trouble running standard envelopes either thru the trays or bypass just set the type to envelopes and make sure the customer selects the desired tray with envelopes selected in the driver
EDSNOW
02-26-2017, 07:20 PM
Many Thanks Luther
Regards
Ed in Whitehorse
Iowatech
02-27-2017, 01:38 AM
Take this for what it is worth please as I've only dealt with envelope printing on Ricohs and Risos.
But keep in mind that feeding envelopes can sometimes be kind of fiddly, as most feed systems are designed to feed one thickness of paper at a time reliably, and envelopes are two to three independent thicknesses.
Manufacturer's recommended envelopes fed exactly as outlined in the user guide are usually OK (may be some accelerated roller wear in the feed area, maybe not), other types may require some experimentation or may not work acceptably at all, that's just the way it goes.
If the operators of the machines aren't patient and thoughtful, envelopes could be a bad deal too.
EDSNOW
02-27-2017, 02:05 PM
Many Thanks Iowatech
I quite agree with you.
Regards
Ed in Whitehorse
Tonerkiller
02-27-2017, 02:13 PM
The newer Kyocera MFP's that I work on, run envelopes perfectly.
EDSNOW
02-27-2017, 02:23 PM
Thank you Tonerkiller.
Ed
