View Full Version : Altenative developer for use in C550
chiapas
03-02-2017, 02:59 PM
Hi , I trade an old c550 with the detail that the black print is very faint, the other colors print well. Before buying a $ 300 image unit, I would like to test if the problem its on the imaging unit. Already disassemble the black UI, clean and dump the developer. The cleaning blade and the drum look good. There are no stains or streaks on the sheet.
The problem is that I can not find the developer separately. I wonder if it is possible to use another konica developer model even though the weight is smaller just to try.
The developers who are common and cheap:
DV510K for Bizhub C500 PRO
DV511 Bizhub 500 501 420 421 360
DV610K Black Developer for Bizhub PRESS C6000 C7000 C70HC
