View Full Version : NVRAM recovery FW
ColorMaster
03-06-2017, 09:05 AM
Hi friends,
any friend can send me C450 NVRAM recovery FW. it will be greatly appreciated.
use my PM.
Thanks in advance
ColorMaster
tulintron
03-06-2017, 12:34 PM
Hi friends,
use my PM.
Thanks in advance
ColorMaster
C450/C351/C250/C252/C352/C300
NOTE: GCN-G4 firmware can be used to reset the NVRAM without losing counter data. See Appendix C.
Note that the Recovery Software cannot be used on the “P” models. Install the NVRAM on a non-"P"
version machine and install the recovery firmware. When complete, return the NVRAM to the original
"P" machine.
1. Install latest firmware.
2. The only confirmed issue is when the screen freezes on the hourglass. If the machine gets stuck
on the hour glass please let it sit for 5 minutes. If it is still stuck after 5 minutes replace the
NVRAM. Check the memory DIMMs before NVRAM replacement (see Appendix B).
3. Check management lists from another working machine to see what settings are different
(parameter sheets).
4. Perform Initialization (Data Clear).
a. Service => System 1 => Initialization.
5. Initialize the Fax (if a fax issue is occurring).
a. Service => Fax => Initialization.
