captain
03-07-2017, 03:13 PM
I'm having an issue where the unit marked with the sticker FN1 in this FS-532 (the unit that houses the finishers lower registration roller) seems to be falling down. It is almost like it is not latching all the way unless you put more force than normal when locking it back in place prior to removing a jam. Generally any jams will occur when the finisher will go to staple because the finisher will shake just enough to dislodge FN1.
I have ordered the spring that holds tension on the latch that holds this unit into place (p/n A4F3704100) and the latchees(p/n A4F3705700). Konica sent me the wrong spring so I am waiting for the second order to come in with hopefully the right spring:rolleyes:
I was just wondering if anyone else has come across an issue similar to this?
