View Full Version : bizhub 421 poor printing output
landpromise
03-10-2017, 06:17 AM
gday guys
our bizhub 421 printer is printing documents and missing a section of ink about a quarter down the page
so on a particular page youll see a white line horizontally across an A4 sheet about a centimeter thick
ive sprayed the inside of the printer out with circuit board spray and tried to get the crap off the rollers, it hasnt helped
not sure what else to do, any ideas?
mo0651
03-10-2017, 01:58 PM
Scan in and post an image, and tell us feed direction. Always helpful. Could be a Dev unit.:cool:
Woxner
03-10-2017, 04:04 PM
could be dirty t corona, charge corona or blank spot in dev unit. transfer corona tend to blank out on these esp when dirty. they wont code until they short complety for 5 times in a row.
landpromise
03-11-2017, 05:41 AM
thanks guys
we actually have another clone of this 421 printer in the shed
i could swap bits off it, which is what i did with the big fusing unit when the faults started occurring
i really dont know what your talking about with components, but if could lead me to a few links that would be brilliant
its the weekend im only here at work for a half hour but by tuesday can reply thoroughly
i will also get a photo of the output asap
landpromise
03-14-2017, 07:46 AM
so heres the issue any ideas why this is happening?.....
(inkless area on right side)
the developer unit does look to have a ink dust trails on the roller where this ink is missing
do i have to take the fusing unit out to get the dev unit out??
35896
darry1322
03-14-2017, 11:37 AM
It may be something blocking the laser from hitting the drum in that area.
CraigW
03-14-2017, 01:03 PM
^^^ Yes, check the cleaners status behind front door. Smallest, lowest knob.
blackcat4866
03-14-2017, 01:33 PM
Yes, it looks like a dirty laser slit glass to me. =^..^=
myster
03-14-2017, 06:37 PM
cleanner of the main charge corona ??
landpromise
03-17-2017, 03:18 AM
well oh my god, i cleaned the pins you mentioned from behind the front small door
and cleaned the slit glass and its printing fine now
unbelievable a 20 second job
which do we believe did it, the slit or cleaning the pins?
how do i clean the coroner champ
copier addict
03-17-2017, 01:17 PM
If the charge corona was being blocked he would have been getting black lines, not void lines.
