View Full Version : BIZ HUB 280
antone
03-11-2017, 01:07 AM
Error message CE002....only with network cable in port.Cable good..network good...With out cable in port copier runs fine!!!Any tricks..?
Sent from my SM-N920V using Tapatalk
Synthohol
03-11-2017, 01:35 AM
ping the IP with it unplugged, see if there is a conflict?
blackcat4866
03-11-2017, 01:54 AM
What happens if you crossover to your laptop? =^..^=
antone
03-11-2017, 01:55 AM
IT...chk this out...hooked up computer ect....not the .network
blackcat4866
03-11-2017, 01:57 AM
Does this mean that it communicated directly to the laptop, or did not? =^..^=
antone
03-11-2017, 01:58 AM
Yes it did....
blackcat4866
03-11-2017, 02:01 AM
If it communicated with the laptop then the problem is on the network. Did you check for a dupe like Synthohol suggests? =^..^=
antone
03-11-2017, 02:02 AM
Cross over cable...directy
blackcat4866
03-11-2017, 04:52 PM
I do not understand how this answers the question.
Did you check for a duplicate IP address on the network? Unplug the MFP from the network > connect your laptop to the network cable > ping the IP address > does anything answer back? > if yes, something else is using the same IP address.
If this is the case you can use a utility like Network Scanner to identify the MAC address and consequently the maker of the network device. If you have a lot of network devices on the network it still can be difficult to find the offending device. It's generally easier to change the IP address to an open/unused address at the MFP and at the print driver.
antone
03-11-2017, 04:59 PM
I did all those things...ordered a hard drive MFP board..some thing up with the copier!
blackcat4866
03-11-2017, 05:16 PM
I don't think we're speaking the same language. That's fine. It seems like you have a plan. =^..^=
antone
03-15-2017, 02:28 AM
Thanks ...trying a hard drive
allan
03-15-2017, 05:06 AM
May the force be with you.:confused:
k2@bpos.ca
03-15-2017, 05:46 AM
I had a similar issue with a c353. Ended up being the hard drive. Replaced and all was good.
Sent from my STV100-3 using Tapatalk
antone
03-15-2017, 01:13 PM
I will let you know
antone
03-15-2017, 02:47 PM
Hard drive fixed ..
Problem....ok
