Staggan
03-14-2017, 11:13 PM
Hello
I have a C253 showing a C0202 error...
It seemed to be a damaged lift motor, the plastic clips had snapped off the motor assembly allowing the end to fall off...
The motor has been replaced, but still getting the error...
I tried swapping the lift sensors between tray 1 and 2, but the fault remains with tray 1... There are, or appear to be no obstructions... certainly no paper jammed anywhere which is the normal cause of this issue....
Any suggestions?
Any suggestions?
