View Full Version : help!!!! with konica 70xx feed mod, pls!!!
Hi just wondering if someone can help me , I've heard that there is a feed mod(thats been around for ages!!!) for the paper pickup/feed assy in konica 7020-7145 apparently the whole feed assy has been changed from the original poorly designed feed sys. i have worked on many of these mc's with feed issues, can anyone help??
10871087
09-07-2006, 04:44 AM
Are you talking about the document feeder (RADF)? I found this in a bulletin from Konica, let me know if you want all of it.
Date: 07/06/04
To: All Konica Minolta Digital Copier Dealers
Subject: RADF UNIT ENHANCEMENTS
DF-314: 003
PURPOSE OF CHANGE:
Changes to RADF DF-314 have been made to: (1) strengthen the hinge area of the unit, (2) provide
commonality of parts with other models, and (3) prevent skewing of original.
I'm talking about the paper pickup in the cassettes sorry should have been more specific.
yes they are a modification kit out for that. all it is is the hub and shaft. what happened is the old style had a smaller shaft and it wore the inside of the hub of the feed tire out causing the shaft to spin inside the hub. they have made the shaft bigger and the hub to fit the shaft. bad part is, i can't find the part number, been a while since i used one. but if i can find one i will post it.
knightfall
09-08-2006, 11:35 AM
Hi T566
there is a mod that changes the pf ass'y and the gears, apparently due to dirt and paper dust getting into the shaft puts pressure on the gears. The symptoms are noise and jamming. I have that bulletin as soon as I find it i'll email over.
knightfall
09-08-2006, 11:47 AM
Hi T566
here is the part numbers.
Paper feed gear/2 assembly 26NA–1681
Paper feed gear/3 assembly 26NA–1691
Drive auxiliary panel B 40LA–1030
Drive auxiliary panel C 40LA–1040
this change is for 7020, 7022, 7025, 7030, 7035, 7130, 7135
if you give me your email I can email the bulletin to you
Thanks for the help guys my email is andrew_ancilleri@hotmail.com
the mod i've been told about is a change to the actual pickup and feed tyre assy, so basically you remove the old tyres and replace them with a whole new assy. does anyone know of this????
CraigW
02-09-2011, 01:50 PM
This may be old news (to go with an old thread) The new style Pickup Roller Assembly for the 7020-7145 models is 40LA-4051 you will also need a 26NA40120 Lower DFPV Tire in addition.
This new unit has worked out well for us to solve many feed issues (and some not)
