View Full Version : BizHub C220 Firmware - How to Install?!
TheAlikA
03-19-2017, 10:39 PM
I found firmware for my "Olivetti d-Color MF220" which is the same thing as the Konica Minolta c220 for everyone else.
Index de ./Machine Couleur/Copieur Couleur/D-Color MF220-280-360/Firmware/ (http://upload.olivettifrance.fr/2index.php?dir=Machine%20Couleur/Copieur%20Couleur/D-Color%20MF220-280-360/Firmware/) << this is the Link
The latest firmware is the G00-C06 but How do I install it?
Here is what I have tried so far:
Step 1: Download file: A0ED0Y0-F000-G00-C6.exe (http://upload.olivettifrance.fr/2index.php?dir=Machine%20Couleur/Copieur%20Couleur/D-Color%20MF220-280-360/Firmware/G00-C6%20%28%20code%20C152%29/&file=A0ED0Y0-F000-G00-C6.exe)
Step 2: Format 16GB USB2 Flash drive to FAT32
Step 3: Extract files from the .exe
Step 4: Copy the extracted files to USB
Step 5: Place the USB a the back of the printer and switch it on.
Step 6: .... nothing happens
Please Help.
I tried extracting files and placing the .exe file in the root directory, I also tried different firmware...
copyman
03-20-2017, 01:20 AM
Use a flash drive 4GB or less. Copy and paste only the .tar file to the flash drive. Use service port behind small cover on right rear. Install with "main switch" off, then turn on. May take several mins for firmware screen to appear.
copier tech
03-20-2017, 08:02 AM
Yes assuming you have the correct firmware you simply put the .tar file onto a USB drive no larger than 2GB.
Also the version you have is outdated, GDH-D1 is the latest available.
35961
korthr5
03-20-2017, 10:14 AM
Please Help.
Hello
On Step 5 you can not put in any USB on back.. Only on the hidden USB.
TheAlikA
03-20-2017, 02:26 PM
35961
Thanks for the explanation. ;)
Also your firmware costs £20 (Not a price I am willing to pay for code written by Konica Minolta)
copyman
03-21-2017, 12:57 AM
What do you mean the firmware cost money? Is someone trying to sell you Firmware on this website? No one should be charging for F/W or manuals!
TheAlikA
03-21-2017, 12:10 PM
Well, no one is sure as hell giving it away for free!
As a matter of fact, most sharks here reply with: "I have it, see my website -or- PM me but it's not free" and there is the usual price of £20 for a link.
It get's worse I had a seller of firmware contact me and ask me to remove the link I found and posted here of free downloads, he claims that because people will download the software the site will experience an overload and shut down. When in reality I suppose he just does not want the competition.
In other words, there are plenty of sharks here, and one really has to do his own research to find anything that is actually worthwhile.
I'd suggest that the people who already bought this software/firmware create a torrent which is going to be kept up by this community, and put those greedy SoB out of business!
TheAlikA
03-21-2017, 12:23 PM
Firstly, that is exactly what I was doing, and also what I mentioned in my post, but thanks for confirming.
Secondly, I disagree... there is a USB extension cable that runs from the back service port to the front user accessible port, that's the only difference. How that will affect data transfer I can not see possible. (I'm including a screenshot just to be clear)
36037
avecosat
03-21-2017, 12:42 PM
The only valid usb is the one that is covered
summercloud
03-21-2017, 12:46 PM
36037
Just registered to this site to write you a message.
Yesterday was trying to upgrade same firmware and had same issues.
There is a third USB port in the back behind the screw:
36038
You have to insert the flash drive to that port when the main switch is off. Then turn the machine on and firmware upgrade will boot up.
copyman
03-21-2017, 12:57 PM
The USB port on right side by control panel is for end user convenience to insert flash drive. This port can also be used to load "special" F/W but only movie, voice & OCR data. ALL other F/W has to be installed with port behind small cover. The reason there is a cover over port is because it is only for firmware.
Let me know if you need Konica Minolta F/W for FREE. I will only provide it to "long term" members of this site. I will not reply to anyone else or to anyone that sells F/W !!!
TheAlikA
03-21-2017, 02:17 PM
There is a third USB port in the back, behind the screw:
YES!!!
That worked!!
36039
36040
After the firmware installs, do you simply unplug the printer, or must you do something to shut down saftley?
summercloud
03-21-2017, 02:37 PM
Shut down by turning MAIN SWITCH off:
36041
The best manual I found: https://www.manualslib.com/manual/433026/Konica-Minolta-Bizhub-C280.html?page=33#manual
hussainsalget
06-22-2021, 04:13 PM
it doesn't work
Please Help.
emujo2
06-22-2021, 04:48 PM
You are mistaken, he said it worked..If you are referring to your own machine try starting your own thread. E
LODAN31
08-18-2021, 04:28 PM
hello, I am looking for the firmware for bizhub C220, can you provide it to me? thank you very much
copier tech
08-18-2021, 07:23 PM
Happy to help with this.
Please contact us at the links below.
