View Full Version : bizhub error C-3B04???
bizhubc451
08-08-2008, 02:03 PM
Does anyone know what error C-3B04 is?? I have a BizHub C451. I think it might have something to do with a power surge we had in our office??
lvangsnes
08-08-2008, 04:02 PM
Sounds like it may be a finisher error. Try disconnecting the finisher, clear the code and see if it comes back. I'll have to research the exact code.
bgbas
08-08-2008, 08:23 PM
Here is what I found for that code
Subject:
Intermittent C-3B04 (C3B04).
Description:
Intermittent C-3B04.
Solution:
CAUSE: Power problem in the fusing unit.
Solution: Replace the IH power supply (IHPU, p/n A00J-M400-03) and fusing unit coil (p/n A00J-R751-00).
Hope it points you in the right direction.
bizhubc451
08-08-2008, 09:13 PM
Thank you! I will check that out and let you know.
leo
08-11-2008, 10:44 AM
its a fuser error
turn off the powerswitch behind the little white cover
hold down the utility /counter buttom while power on and hold it until the hourglass shows.
after a while the displays shows a trouble reset, press it and you will get ok i result.
power off/on again.
if you still get an c- code please come back for more details.
bizhubc451
08-11-2008, 01:45 PM
Thank you!!!! That did it!! Wow thank you very much!!
leo
08-12-2008, 09:19 AM
:):):) NOP
Sharon
04-08-2009, 11:12 PM
Wow! Thanks leo!!!!!!!! I had the same problem. Your solution worked just as you said. :)
leo
04-14-2009, 07:39 AM
glad to help u all!
Farrukh Ahmad
01-18-2015, 05:37 PM
glad to help u all!I had same problem.i reset it and it works for few prints and after it gives again error..please help me.
leo
01-20-2015, 02:27 PM
You need a new fuser unit.
Or if you have one , a new heater-fuse
It is esyer to change the whole fuserunit but more expensive
hotfuser
01-20-2015, 03:38 PM
C-3B04 is usually the IH PU at the front of the copier. I have had a IH unit fail once that goes open circuit.
9 times out of 10 its the IH PU that fails.
EarthKmTech
01-22-2015, 06:20 AM
Hotfuser is bang on the money.
Changed many of the ihpu in my time.
To date have only ever changed 2 coils both catastrophically failed - there was no guess work involved.
