View Full Version : PRESS C5501 !!
Shinigami
03-31-2017, 10:07 AM
Hello friends!
Can you help me please in this problem!
Machine : konica minolta press C5501
problem : trouble code " C-0213 " with paper jamp
(品 change the PS10 paper exit senor
付he motor M45 not turn ! I switched him with M30 ! The same problem
品 change the PRCB )
same problem 🤔🤔
Synthohol
03-31-2017, 11:00 AM
check the gears 15 and 16, one is a one way gear that slips.
sand down the shaft and clean the needle bearings with IPA.
Shinigami
03-31-2017, 04:28 PM
I changed both !
I do the test mode of I/O
27-20 motor not turn ,Even if empty without gears !
Synthohol
03-31-2017, 07:11 PM
ok, now its down to the connectors, motor or PRCB i believe.
do you get 24v to the motor at all times? the prcb sends the ground to make the motor turn if memory serves.
Shinigami
03-31-2017, 11:55 PM
I changed the PRCB AND THE MOTOR
what about the ACDB ??
Synthohol
04-01-2017, 12:28 AM
Error
C-0213
Root Cause
C-0213 code when Start button is pressed at Ready or intermittently during operation.
Workaround/Fix
PROBABLE CAUSES:
1. A one-way paper exit drive gear is slipping.
Replace Paper Exit Gear/2 - 29T (p/n A03U 9098 00), Paper Exit Gear/3 - 23T (p/n A03U 9097 01), Paper Exit Gear/4 - 37T (p/n A03U 9096 00) and/or Paper Exit Gear/5 - 40T (p/n A03U 9095 02) as necessary.
2. Dirty or failed Paper Exit Pressure Home sensor (PS10).
Verify operation in I/O Check Mode, input code 27-25. Clean or replace PS10 as necessary (p/n 08AA 8551 2). Please refer to attached C0213 document for more detailed information.
3. Paper Exit motor (M54) failed.
Verify operation in I/O Check Mode, output code 27-25. Replace M54 (p/n A03U M111 00) if necessary.
4. Open ICP2 (24V DC) on the ACDB.
Replace the ACDB (p/n A03U H520 02).
5. Original style regulating shaft is installed. (bizhub PRO C6500/C6500P/C5500 only)
Install modified Paper Exit Regulating shaft (p/n A03U 8929 02).
Note: Please refer to attached Parts Modification Notice and ExitSection parts document.
6. The wiring for M54 has been damaged by the rear side of the paper transport section or rear section of the paper transport unit bracket contacting the harness.
Inspect the wiring harness to M54 and replace as needed (p/n A03U N213 02).
Note: Please review the attached WireDamage document for images of the wire harness and suspect section of the paper transport. Also, refer to attached C0213 document for more detailed information.
this is all i have for ya, hope something helps!
good luck!
afterhours
04-01-2017, 11:09 PM
Solution ID TAUS0800312EN* Solution Usage 25
Description
Solution
PROBABLE CAUSES:
Replace Paper Exit Gear/2 - 29T(p/n A03U 9098 00), Paper Exit Gear/3 - 23T(p/n A03U 9097 01), Paper Exit Gear/4 - 37T(p/n A03U 9096 00) and/or Paper
Exit Gear/5 - 40T(p/n A03U 9095 02) as necessary.
Verify operation in I/O Check Mode,input code 27-25. Clean or replace PS10 as necessary (p/n 08AA 8551 2). Please refer to attached C0213 document for
3. Paper Exit motor(M54) failed.
Verify operation in I/O Check Mode,output code 27-25. Replace M54(p/n A03U M111 00) if necessary.
5. Original style regulating shaft is installed . ( bizhub PRO C6500/C6500P/C5500 only)
Installmodified Paper Exit Regulating shaft (p/n A03U 8929 02).
Synthohol
04-02-2017, 04:49 PM
wish i'd said it first ;)
