View Full Version : DF621 on Bizhub 223, 283, 363, 423 jam code 66-02
Don N.
04-07-2017, 10:31 PM
This has got several of us techs puzzled. We've read the posts on the 66-02 jam code here and the bulletins (attached) from Konica Minolta. Code 66-02 is a failure to feed. Obviously, bald tires can be the cause. There is a second occasion where all sheets are fed completely, but the tires turn after there is nothing there. That is the 66-02 I am looking to solve. I have a video I will attempt to link or attach.
https://drive.google.com/file/d/0B0TP29a-CrlDWTBpdTF1TWRZdHM/view?usp=sharing
Several customers, usually law firms complain of hearing the distinctive sound of the tires feeding against the black felt pads AFTER the last sheet had gone through.
Watch for that in the video.
We have done the following:
Installed washer/shim to center the p. empty actuator on some units where the actuator would hit the side of the plate, per bulletin.
Replaced with new oem parts:
Front & rear arms A143PP9P01 & A143PP9Q01
Paper empty actuator lever A143PP5G01
Paper empty photodetector A143PP4800
Drive clutch/spring/gear ass'y A143PP9R00 on rear of shaft
Previously replaced primary feed, secondary feed & sep tires.
All machines have latest G00-D6 FW.
For two customers we swapped the entire feeder out, taken from off lease machines with under 10k on the feeder. The original feeders had ADF page counts of well under 50k and we replaced the tires & tested in shop. This seems most prevalent when scanning at 200x200 or 200x300 dpi (fastest speeds), less evident on copying, which I believe is a 600dpi scan. the bottom line is the feeder thinks there is another page, so we think the empty lever is not dropping fast enough. This model does not have a spring on the empty lever, but the color series C220's do have a spring.
3628636287
Don N.
04-07-2017, 10:38 PM
Keep in mind it would have fed as many sheets as they want, but after the last sheet it is turning the tires to feed another sheet instead of raising the arms up. That means a forward turn of the motor, not a reverse turn to raise the tires. The resulting 66-02 in the jam counts is because it tried to feed an original but it did not make it to the registration sensor. (DUH, there's no original to feed!) The noise is the tires against the black friction pads. I've seen it in person several times. It's not a belt slipping. Sorry the audio is rough. Maybe I will re-post the video in slo-mo.
habik
04-07-2017, 11:40 PM
Have you tried system error clear? Trouble reset?
Sent from my iDon't believe in marketing device using Tapatalk
TheBlueOrleans
04-08-2017, 01:22 PM
Perform Sensor Check in the ADF section of service mode, once when the machine is stuck on the code, and if possible, once while the machine is in ready state. Compare reading differences. Machine is receiving signal that paper is present, thus tries to feed it. Really sounds like a dirty sensor to me.
service_man
04-08-2017, 01:25 PM
I hear some noise when paper is in exit section.
Did you check timing belt, or some wiring is in out of position?
I think that is mechanical problem.
Pull uot covers, and try to see gear, timing belt, and wire.
Good Luck
Don N.
04-08-2017, 03:04 PM
Service_Man- The noise is the tires on the felt pads. There is no problem or noise with exit. I know the audio sounds different, but LOOK AT THE TIRES in the down position, feeding when there is no original
TheBlueOrleans- This problem happens intermittently. It only triggers a jam. It is never stuck in a code. 66-02 is the code you see when you check jams under counter in service mode. You can't be in sensor check mode and make it happen. Paper empty sensor was replaced, all sensors are clean.
blackcat4866
04-08-2017, 04:12 PM
I've seen this particular problem on a Toshiba eS6540 document feeder and on a Kyocera Alphard II document feeder. On the Toshiba it comes up as a E712 code. This fits with your bulletin about the flag hitting the side of the valley. A minor reforming of the metal shaft that the flag rides on fixes this issue.
36289
On the Kyocera it is a J9000 code. After watching the flag drop following the last original leaving the tray, you may see the flag bounce, triggering the photointerrupter twice. These flags are gravity operated, and I've heard of techs adding weight to the flag. Personally I added a very very weak torsion spring. I wasn't concerned about how fast the flag returned, just that it did not bounce. There was not a convenient place to position the spring end, so I carved a small "V" shaped groove in the cover, and placed a spot of cyanoacetate on the contact point.
3629036288
Don N.
04-08-2017, 04:47 PM
Black Cat4866- I'm looking at how & where I can add a spring also. Weight didn't help. We are on top of placing shim washers on units that the flag may hit the side of the valley. I will post results after giving field trials a week or two. Shop tests just don't seem to be as accurate as weeks in the field.
blackcat4866
04-09-2017, 01:42 AM
It was a third or fourth call in which I was amazingly lucky enough to actually see the flag bounce on the Kyocera. The previous techs had seen no symptoms. It had happened three times in a row for me. The thing that clued me was when I placed only one original, and the MFP told me to load 2nd original again. Clearly there was no second original, but the machine thought there was. This DF would function with the outer top cover off, so it was easy to view the flag.
The Toshiba would not function with the top door off, but by then I kinda knew where to look for the original detection sensor flag.
Good luck. =^..^=
Don N.
04-09-2017, 03:17 AM
I can't easily add a spring, but found a half fix by lowering the angle of the sensor to make the flag have to bounce higher to think another original exists. Now I have the problem of it always leaving one sheet. I'm not done yet, but it's looking like it's coming down to a warped lid. All I have to do is press down and it works perfect. That lowers the flag to a position where it's angled and if it were to hit the shaft at that spot, it doesn't bounce and it reads paper correctly down to and including the last sheet.
Here's two videos in slo-mo. Wait for paper to stop at registration roller, so far so good... after the paper is gone, when flag falls against the shaft, if it bounces too much, it causes a re-feed. The only diff between these two videos is weight on the lid, lowering the flag, making the flag hit the metal shaft at the sweet (bent) spot causing minimal bounce.
This is with weight, minimal bounce: https://goo.gl/photos/8t5wos7eANJcPpLVA
This is with a felt pad trying to limit bounce, but actually bounced worse, causing the symptom my customers report: https://goo.gl/photos/ZeDLqw8jrTvEXrH49
blackcat4866
04-09-2017, 01:46 PM
The video tells the whole story. I could have told you that a pad of any sort would make it worse. You might try a weak magnet (like a refrigerator magnet). The flag will cling to the pickup shaft, damping the bounce. =^..^=
JR2ALTA
04-09-2017, 03:02 PM
Doesn't the Bizhub 200 series have a detect flag-spring you could order of steal off a parts machine?
Don N.
04-09-2017, 06:12 PM
A spring won't fit. I also noticed the flag is high enough due to the warped cover, that it lets a piece (or several) get underneath of it. Pressing down lets the flag hit at the bend and not bounce. The bounce causes it to detect no paper, or not detect the last sheet. I'm placing about 40 lbs on top of all DF621's in the shop all weekend to see if they will flatten out. Then I will swap any feeders in the field that have 66-02 codes and good tires, and especially any where the customer notices "that sound" after the last page has exited and it tries to feed nothing.
If weight alone won't un-warp them, I'll treat them to some heat & weight. The darn left cover ass'y A143PP9N02 is about $200 cost, and you get to re-mount all sensors plus about 20 other parts and re-thread the harness....
Don N.
04-09-2017, 06:14 PM
Your suggestions continue to impress me, but see comment below.
Don N.
04-24-2017, 03:07 AM
Placing about 20-30 lbs weight on top of the DF621 left cover (lid) for a week has reduced the warp on each cover in our shop from 24~26 mm to 23~24 mm measured from the center of the doc tray to the bottom edge of the lid. Several days later they have not warped back up more than .5 mm. So I'll swap units in the field and see how long that lasts. Any more than 24 mm may cause some switch bounce and feeding of a final original that does not exist.
blackcat4866
04-24-2017, 03:45 AM
That sounds like success, at least in the short term. Please keep us posted how it progresses. =^..^=
CraigW
04-24-2017, 01:46 PM
I think this to be a model feeder that has a modified paper present actuator available that can accept a magnet to prevent this from occurring.
Don N.
05-12-2017, 03:46 AM
CraigW: I haven't seen a part # or any mention of that. Again, if it's warped up high enough, paper can get under the flag and cause other issues. Best to get the lid flattened back down to less than 25mm. Most working units in the field are about 23~24 mm. See pic of measurement.
36587
CraigW
05-12-2017, 01:44 PM
Actuator = A3CFPP4VOO
Magnet = A3CFPP1700
The 621 IIRC does NOT have these from factory though.
Don N.
05-12-2017, 03:49 PM
Magnet = A3CFPP1700
CraigW - My Nov. 2014 parts manual does not have this part listed. Is this definitely a DF621 part? Not sure what IIRC means.
THANKS!
CraigW
05-12-2017, 04:34 PM
This parts change is only 1-1.5 years old.
KMBS still has the same 2014 version parts manual on their site.
IIRC= If I Remember Correctly.
Don N.
06-01-2017, 03:10 PM
Magnet = A3CFPP1700
I tried to put the actuator with magnet A3CFPP4VOO from a 4/e series (DF624 & DF701) onto a DF621 (BH223 series) and it won't work. The top end is too big, preventing it from swinging completely down.
Still some value in gluing the magnet only A3CFPP1700 onto the old style DF621 actuator as long as the lid is not warped above 25+ mm.
Don N.
01-22-2021, 04:35 PM
Originally Posted by CraigW http://www.copytechnet.com/forums/images/buttons/viewpost-right.png (https://www.copytechnet.com/forums/konica-minolta/118602-df621-bizhub-223-283-363-423-jam-code-66-02-a-post562760.html#post562760)
Magnet = A3CFPP1700
Just to close out this old post, that new style lever & magnet for the 4e series DF629 & DF701 is working well on these older DF621 on 223 series. We just had to cut a couple of mm off the top of the new 4e style lever... Nipping it just at the top of the round circle stamped into the top with a number in it.
THANKS CRAIGW!
