View Full Version : Konica menolta bizhub adf adjustments are unavailable
khadimetareqat
04-09-2017, 09:00 AM
HI DEAR
MY KONICA MENOLTA BIZHUB DCOLOR 652 CANTS SHOWING THEIR ADF ADJUSTMENTS ,
AFTER NVRAM REFRESH IT REQUIRED THE ADF ADJUSTMENT BUT ADJUSTMENTS MENU IS UNAVAILABLE , kindly guide me ?
ADF is working , only adjustments menu is unavailable in both service and administrator menu/
Ahmad shah
service_man
04-09-2017, 09:29 AM
Hello,
Try to change the FW,
Check the connector on the ADF.
Regards
khadimetareqat
04-09-2017, 01:48 PM
ok
sir their is only two firmwares are available for that machine
can you send me the latest version of dcolor652
thanks
Synthohol
04-09-2017, 11:27 PM
it it a Bizhub C652?
there are 33 base FW versions and 200 special.
what ver do you have now?
khadimetareqat
04-10-2017, 03:35 AM
my current version is
MFP Controler Boot program
A0p00Y0-1E00-G00-02
thanks
khadimetareqat
04-10-2017, 03:59 AM
MFP Controller BOOT Program
A0P00Y0-1E00-G00-02(00)
MFP Controller SubSet
A0P00Y0-1F00-G00-14(00)
MFP Controller
A0P00Y0-0100-G00-D1(00)
Operation Panel Message Data
A0P00Y0-8100-G00-D1-100
Fax Board Controller1
Fax Board Controller2
Scanner
A0P00Y0-0023-G00-82
Printer
A0P00Y0-0050-G00-16
ADF
A0HT0Y0-0024-G00-04
Finisher
RU
ZU
Panel CPU
A0P00Y0-8900-G01-01
Loadable Device Driver
Voice Data
Movie Data
A0P00Y0-A000-G00-03
MFP Controller System
A0P00Y0-1000-G00-D1(00)
MFP Controller Print Controller
A0P00Y0-3000-G00-AH
MFP Controller Print Controller Font
A0P00Y0-3F00-G00-35
MFP Controller Print Controller Demo Page
A0P00Y0-3E00-G00-01
MFP Controller MIO
A0P00Y0-5000-G00-27(00)
MFP Controller PSWC
A0P00Y0-5100-G00-20(00)
MFP Controller MIB IF
A0P00Y0-5200-G00-10
MFP Controller IPP IF
A0P00Y0-5300-G00-10
MFP Controller Outside Controller IF
MFP Controller TCP/Socket
A0P00Y0-6300-G00-21(00)
MFP Controller OPEN API
A0P00Y0-7000-G00-13(00)
MFP Controller Operation Panel
A0P00Y0-8000-G00-D1(00)
MFP Controller CSRC Control Body
A0P00Y0-8300-G00-02(00)
MFP Controller PIC
A0P00Y0-8200-G00-A1
Synthohol
04-10-2017, 04:40 AM
is it a C652 or C652DS?
khadimetareqat
04-10-2017, 05:03 AM
its olivetti dcolor651 which is konica menolta dcolor 652
Synthohol
04-10-2017, 06:41 AM
if you print out a network config page, what model does it show? the "C652" controller or "generic"?
khadimetareqat
04-10-2017, 07:21 AM
generic 50C
Synthohol
04-10-2017, 02:37 PM
Ok well thats an issue there.
There is a bit switch or 2 to change when you did the nvram clear for some unknown reason.
Solution
CAUSE: Incorrect settings.
SOLUTION: To change the Configuration Page header to Konica Minolta bizhub, please perform the following:
1. Access the Service Mode.
2. Select System 2.
3. Select Software Switch Setting.
4. Enter Switch No. "10".
5. Bin Assignment "00000000".
6. Hex Assignment "02".
7. Click on Fix.
8. Click on End.
9. Power the MFP OFF/ON.
also
switch 25 has to be set to whatever it was before the nvram clear.
then check system 1 marketing area and also make sure in system 2 the HDD shows as installed.
khadimetareqat
04-10-2017, 03:44 PM
sir in software swich
i perform that but their is below detail
5. Bin Assignment "00000010".
7. Click on Fix.
8. Click on End.
after that machine changed their bootup screen to konica menolta and lines issue is still their
i have a documnet about software switch setting kindly guide me a bout what another think to 36305chnage
Synthohol
04-10-2017, 04:15 PM
what lines issue? we were discussing the unavailable ADF adjustments.
try following the initial setup to detail and exact order.
you will need 11x17 (A3) paper for the many gradations.
serial numbers, time etc...
just follow it from start to finish.
khadimetareqat
04-11-2017, 03:39 AM
yes
we were discussing adf adjustments
after that switch adf adjustments are also unavailable
hdd is instaled
gradation and serial number time and date setting is done
i think only adf setting is incomplete
Synthohol
04-11-2017, 04:47 AM
try service mode system initialization system ERROR clear hit start then reboot when indicated.
see if that helps.
khadimetareqat
04-11-2017, 03:24 PM
ok
khadimetareqat
04-11-2017, 03:49 PM
still adf adjustments unable
Synthohol
04-11-2017, 04:45 PM
is the serial number for scanner and adf entered?
khadimetareqat
04-12-2017, 03:22 AM
yes
same serial number entered for all feilds
(same machine serial number)
for
like printer
Adf
scaner
iv
ur
and another feilds
Synthohol
04-12-2017, 03:44 AM
serial #s should be different for all components
khadimetareqat
04-12-2017, 07:52 AM
how can i cheq serial numbers for all components?
khadimetareqat
04-12-2017, 09:03 AM
adf settings is done
my service tech have previously enter the machine serial number for all feilds
now i enter the serial number which is written on small stacker at adf
then i ferform the auto adf adjustments then their is ok signal and then i press set.
now i am going to rest after that i will perform ather adf adjustments like front and then back as guided is instalation manual.
thanks dear your idea is very helpful for me
this machine is new in pakistan and our tech cant know configurations
thanks very much i will contact you soon for futher details
