View Full Version : Miscellaneous Konica Minolta C364 Light Copy/Scan
mearmi
04-13-2017, 05:46 AM
Konica Minolta Bizhub C364 getting Light Copy and Scan. From both ADF and Platen Glass.
Cleaned the mirrors and glass. Print is fine. Any adjustments? Please advise.
Thanks and Regards,
rrrohan
04-13-2017, 07:22 AM
Do a duplex scan (assuming you have a DF701 and tell us if both sides look the same or if 2nd side is ok
mearmi
04-14-2017, 04:52 AM
Thanks for your reply. It is DF-624 and both sides are same.
Regards,
Synthohol
04-14-2017, 05:57 AM
hows the white strip under the glass?
mearmi
04-14-2017, 06:54 AM
It is clean and copier has done only 85K total.
paulrid
04-14-2017, 10:47 AM
Have you tried the gradation for copying?
paul.
mearmi
04-15-2017, 06:33 AM
paul.
Yes! Done it. still same
JR2ALTA
04-15-2017, 06:51 AM
Change original type to text, and/or bump up exposure.
rrrohan
04-15-2017, 02:12 PM
Can you show us a sample
alamsandhu
04-15-2017, 08:19 PM
Clean the CCD
