View Full Version : Mp c4503 Printing slow
ABS tect
04-18-2017, 11:08 PM
4503 printing PDFs very very slow... Everything else seems to print fine. Firmware?? Do you know if there is something this machine needs to print PDFs efficiently? 3mb size file took about 3 minutes to print. Correct driver is installed
sandmanmac
04-19-2017, 03:29 AM
Most likely configured using WSD port rather than TCP/IP. It's almost always the case.
D_L_P
04-19-2017, 02:20 PM
Things I have seen cause slow printing:
1. Print server where lazy it staff does 'new driver' on old printer instead of 'new printer'. Fixed by bypassing print server by adding printer to local workstation with tcp/ip port. Or if you can move a mountain and get their it to completely delete the printer and recreate the printer.
2. Byte counting enabled on tcp/up port. Fixed by disabling byte counting
3. Already listed, print as image thing.
4. Extra protocols slowing down network. Disable appletalk, bonjour, or ipv6 if possible. Sometimes disabling snmp or smb can help too.
4. Excel files printing slow. Open taskmanager and watch the spooler memory usage and then print the job. If it jumps to 5x the size or more the excel file has extra data and formulas. Fixed by deleting last sheet or extra formulas if you can find them, or just copying all the data into a new excel spreadsheet.
5. Rare, but a failing HDD on the printer can do it too. Try formatting it first to see if it improves. If it does I'd replace it.
6. Customer has virus or spyware. Do a disk cleanip and delete files.
In my experience it's mostly on their end. Firmware update, replacing HDD, and disabling protocols is just for show.
Gl
ABS tect
04-19-2017, 03:29 PM
Thanks for the suggestions...its not on wsd...it is on tcp/ip
Yes they are on a server but this particular one i set up on the individual computer using tcp/ip as a new printer with a new driver and still super slow from adobe acrobat pro dc
As for the print as image and all the other protocols I will check all of those and let you know what i found to work (if hopefully any). thank you
COPIERMAN
04-19-2017, 05:13 PM
one thing that i fine if printing from a web page or a pdf if you save it to computer it will print fine. there might be something like a banner running and doesn't know what to do. also look at print file see how big it is will also help see why it is taking a long time. some time developer of web page trying to protect for copyright will put a big font or something to make file big. That why if you save it will take that part out.
ABS tect
04-19-2017, 05:52 PM
Basically I am in the customers email...open an email and there is a pdf attachment that says right next to the file name (3mb)...I open it, hit print...and a five page document takes about 3 minutes to print.
COPIERMAN
04-19-2017, 06:04 PM
had a client same thing but once she save it then printed it was a lot faster. never know how they created pdf sometimes that is part of the problem.
bluedevils477
04-19-2017, 07:50 PM
did you ever figure out a solution, I have the same issue.
4.5MB file
Adobe Reader DC
Windows 7 32-bit
Tried PCL 6 (universal and MPC4503), PCL 5 I have had no luck at all. I am currently updating my last firmware and will test after.
mrwho
04-19-2017, 08:01 PM
On those ocasions, one of the first things I do is trying to print the file with another PDF reader (SumatraPDF is my favourite). If it does print faster, then I throw them the ball and explain the problem is with Acrobat - probably an update. Moreso if it happens in some computers and others print fine.
Phil B.
04-19-2017, 08:23 PM
download the pdf then print it
sandmanmac
04-19-2017, 09:30 PM
I assume that you've double-checked that?
I've set up lots of machines on TCP/IP, and then Windows update comes along and re-enables 'automatic setup of network devices', and re-installs the device on the WSD instead.
Just saying....
I've only just recently started getting smart, and started disabling the WSD devices in the WIM
Just saying....
I have a ton of suggestions as to what "WSD" should stand for, but none of them are fit to print. :p
slimslob
04-20-2017, 07:13 AM
Web Services for Devices.
https://en.wikipedia.org/wiki/Web_Services_for_Devices
copier tech
04-20-2017, 07:55 AM
The poster initially asked could Firmware be the issue? My first reaction to any printing issue is yes, check when version you currently have installed.
update all the firmware before trouble shooting.
ABS tect
04-20-2017, 05:51 PM
Alright y'all...I tried just about every one of these suggestions to no avail. Postscript driver actually made things worse.
After trying all this I plugged my personal laptop into their network and still printed slow... Then, using a switch I connected directly to the mpc with an Ethernet cable and sure enough it printed right away.
So it seems to be something with their server... From what I researched most of the time people are having this issue when connected to a server. Idk though... Still seems strange
brt315
05-16-2017, 02:18 PM
Folks, just had this issue again yesterday, the solution is included in bits and pieces of the other replies (always great info here). Here is a synopsis of ALL the steps I've had to go through to ensure print speed is optimal.
1. Check printer port and make sure TCP/IP port that matches the IP address of machine (underscores after IP are okay) is checked. Often see WSD port checked, which causes slow printing.
2. Check print driver and make sure driver is MPC4503 PCL6 (if PS is not installed on machine) or MPC4503 PS3 (if machine has PS installed). I stay away from Universal print drivers completely.
3. I generally download the current driver and do a fresh new install of printer as a rule if slow printing is present, but certainly if machine was assigned to WSD port. The driver on one of the PC's assigned to WSD was version 1.1.0.0. Driver I downloaded was version 1.4.0.0. You can find your version on the Windows test page. Don't know what version of driver gets loaded when doing an auto-discover/PNP install, but it seems insufficient and nearly all print speed complaints are from Windows 10 auto-configure installs.
4. Couple tips when loading printer - when searching for printer, immediately click "the printer I want to use isn't listed", then uncheck "query the printer..." box and select TCP/IP printer using the IP address. Lastly, check "replace current driver" and browse to your downloaded driver folder.
5. Any print file should be saved locally (I train folks to save file to desktop), then printed, so you are using local print protocols and the local driver. In other words, keep it to what you can control and explain. Printing from within a mail server or from a website adds degree of difficulty to printing that we often aren't able to support.
6. Make sure you open and print file from the best possible program for the print file. For example, Windows 10 wants to open .PDF in Microsoft Edge (indicated by e-PDF or some similar derivative), who knows how Edge manipulates us. Open the .PDF in Acrobat Reader, as most techs and IT are well familiar with that.
7. Print as image box should be checked as a test for .PDF files that print slowly. If there is marked speed improvement when box is checked, the print file likely has embedded data that must be translated by machine controller. This could be the case in Excel, Word, PP, and Adobe Pro or Photoshop. Similar to anti-virus or drug testing of athletes, the ability of the MFP to translate up-to-date and complex embedded print media is dependent on firmware that is usually lagging months behind. Thus, print as image bypasses the embedded info IF that is causing the issue.
8. Lastly, hook up laptop directly to the MFP and print their job if not proprietary or confidential, hopefully you can x-fer job to SD Card or thumb drive to accomplish this. Or print 25 pages of .PDF from a service manual from your laptop then do likewise from their local PC to compare and contrast print speed of the network. At this point, doing this is only to gauge the network impact on print speed, but the real causes in my opinion are the steps above. This step is only for folks who want instant gratification you only get by hooking laptop up directly.
Sorry if this is redundant or too wordy. And if some of my opinions above on WHY are inaccurate, my apologies.
D_L_P
05-16-2017, 02:41 PM
Just to add to the "it's their server thing". Print a printer test page from your laptop, which printed fast, then from their server and compare all the files listed. Showing them the test pages with all the extra or lacking files should help convince them its on their end.
Kyocera used to have an undelete utility that would uninstall print drivers and find any extra dlls or orphan files associated with a driver.
Timmytronic
09-07-2017, 10:28 PM
Hi,I have had this loads on this machine, lower the Resolution down one in the print settings in the Printer System, next to test. It will whizz then. It over rides any of the settings the customer has set which is probably highest DPI and Bit rate.
Hope thats helps.
Tim
copier tech
09-08-2017, 07:28 AM
9. Ensure ALL fw files are kept up to date this also makes a big difference
