View Full Version : Biz Hub pro c500 sc 45-20
captkirk
08-12-2008, 11:42 AM
Machine was running great. Blue and black started getting light. sc 45-20 code pops ups.
drums and developer have about 10,000 copies on them.
we have replaced the image correction unit.still sc45-20.
any ideas?
Luther
08-12-2008, 01:17 PM
You have to replace the transfer belt and rollers and perform the color correction calibration for ps8 and ps9, if the code comes back check the sensors in the 47 mode and replace as necasary, 1st clean the sensors,hope this helps
captkirk
08-12-2008, 01:28 PM
transfer belt and all rollers have been replaced.
in 36 mode we finally were able to get it to automatically color calibrate.
what would be causing the blue and black to look as if it low toner? we can force toner to both but it goes light again.
when we run auto gamma adjustment we get error code 1.
we will keep working until we get it.
Luther
08-12-2008, 01:30 PM
Check and make sure the shutter is opening that covers the sensors
I had the same sort of thing, I had to fit a new colour reg unit complete ( you can fit the new modified c6500). after i ran the setup again the colours were spot on.
captkirk
08-12-2008, 03:02 PM
shutters working fine.
the error code is gone, but we still have the problem of the k,c, and now the m is light. m not as light as c
HORSE
08-13-2008, 05:03 AM
You could have a toner supply issue or maybe the developer, I have had a C500 show 45-20 because the developers was hammered and the colour registration hash marks were not dense enough on the transfer belt usually a few toner refresh cycles was enough to bring it back to clear the fault. Could be that the toner supply unit is not supplying the developers.
captkirk
08-13-2008, 11:10 AM
we have forced toner to the c & K. It does not make the copy any darker.
the developer is brand new in the c. we replaced it yesterday thinking that the developer must have went bad. all four developers only had about 20,000 copies on them. I will try running the toner refresh several times straight and see if it brings it back to color.
thanks everyone for you help. any more ideas
jzheld
09-15-2010, 04:33 PM
Hello, I Have 45-20 on my c500, already change transfer belt, developer (tank as well), all drums, when I'm doing auto color adj it gives me 45-09 have no idea what to do with the machine, I cleaned all the sensors but no luck. Any idea what can be the solution?
jma676
09-15-2010, 05:24 PM
Konica Minolta Bizhub Pro C500 Error SC-4520
Description: C45-20 occurs
Cause:Abnormal termination of color registration control.
1. Normal registration mark is not made on the transfer belt, The sensor can not read it because registration mark is not made correctly on the transfer belt.
Defective parts:(Transfer belt, Drum, Developer, Developing Unit,etc).
2. Defective color registration sensor.
3. Defective printer control board.
4. Defective writing unit.
JMA676.
jzheld
09-15-2010, 05:34 PM
what about 45-09 does it specify anything?
jma676
09-15-2010, 05:47 PM
ok vamos a seguir en un solo sitio.
Estamos aqui: #2 http://www.copytechnet.com/forums/konica-minolta/39816-konica-c500-sc45-09-a.html
