View Full Version : Bizhub 222 email issues and SSL
Cookr
04-21-2017, 02:27 PM
Working on a Bizhub 222 they were having email scanning issues and i was working with there IT and he ended up making an SSL and now we can not access the Webtools on the machine is there anyway around this or can I remove it somehow? I have SSL turned off on the machine and have done a total clear already but still no luck. Thanks
D_L_P
04-21-2017, 04:21 PM
Hate to be the bearer of bad new but the Bizhub 222 does not support the newest version of SSL for SMTP. They will have to setup a SMTP relay without SSL using port 25, there should be a knowledgebase article about it.
Because it's an outdated version of ssl is probably why the web interface doesn't work either.
You should be able to turn off ssl under utility-> Admin 2->security-> SSL/TLS.
Off for html comm.
