View Full Version : Help c8000
Shinigami
04-25-2017, 12:58 PM
36459
Hello everyone !
Can you help me ! I have this problem in konica minolta press C8000
Shinigami
04-25-2017, 01:54 PM
Up
Gaffers01
04-25-2017, 02:36 PM
fusing belt is knackered
Shinigami
04-25-2017, 05:21 PM
But i check it ! It's correctly installed
diananto
05-08-2017, 05:24 PM
Excuse me, is lower belt fusing its been replaced?
Maybe I've seen the same problems before..
The fusing lower belt was already saggy at the front and rear section,
I tried to replace the part and the problem gone.
diananto
Shinigami
05-08-2017, 06:17 PM
diananto
I replace the fusing lower belt ! But the same problem
diananto
05-09-2017, 03:04 AM
In addition to lower fusing belt, which parts has been replaced?
Upper roller and outside heater, already?
maybe you have to replace the main fusing unit with the new one and
elimination one by one where is the problem maker.
I'm also still learning, just wanted to share a little, might help. :)
Shinigami
05-09-2017, 09:14 AM
thank you so much ! i will tray with the haeters ! And fusing roller
