View Full Version : Case in C8000
Shinigami
04-26-2017, 06:47 PM
Hello !
I have this problem in C8000
the fusing belt is changed
thanks for your help
Shinigami
04-26-2017, 08:24 PM
Hello !
A big problem so ?
snoopyed
04-27-2017, 02:06 AM
How many print counters with lower fuser belt unit ? In my case, this image problem will show up when the lower fusing unit is not so good. Some times this problem can not be solved even I replace both fusing roller and lower fusing unit. I thought it is a kind of cancer belong to C8000.
從我的iPhone使用Tapatalk 發送
methogod
05-02-2017, 01:57 AM
you changed the belt, did you changed the upper and lower fusing rollers?
Copyshopnis
10-12-2017, 03:06 PM
Hello !
Hi, did you solve this problem with fuser on konica
JP1
10-13-2017, 01:35 AM
Had this when I,ve replaced lower fuser belt & comes back in a few thousand copies later had to replace the fuser, must get worn metal plates around lower belt area.
You can get metal shimes from Japan -did not work for me.
JP1
10-13-2017, 02:15 AM
See Doc, if fuser has done 5 million replace it
