View Full Version : Konica Minolta C364 Scanner Adjustment Centering - Color Chart
mearmi
04-27-2017, 04:37 AM
Getting problem with Side Edge Margins in Konica C364. From all the paper trays it is same.
For ADF we adjusted in Service Mode by going to Machine-Scan Area and Side Edge and it is fine.
But from the platen glass still getting less margin on the side.
Do we need to have Konica Minolta Color Chart. If someone can send us.
Thanks and Regards,
Max
04-27-2017, 09:05 AM
Check your trays. Make sure the side to side fences are centralized and not off set to one side. Once you get that in the right place for the off the glass copy then adjust the DF.
mearmi
04-29-2017, 06:05 AM
Fences are centralized.
Print is fine but copy from Platen glass is still same. Please find the attachment. Thanks
36509
Synthohol
04-29-2017, 06:08 AM
is the long or short edge the lead edge?
blackcat4866
04-29-2017, 02:38 PM
Excuse me for saying so, but isn't you're image reduced 8% along the short edge and 3% along the long edge, if those arrows were touching the edge of an A4 original? Don't you thing you should address that first, before trying to move the image around? =^..^=
mearmi
05-01-2017, 03:34 AM
Leading Edge is fine.
It is Long Edge (Landscape).
Synthohol
05-01-2017, 04:05 AM
long edge is portrait.
please clarify.
allan
05-01-2017, 06:29 AM
You have to do print area then do scan area. Do all the adjustments including the magnification adjustment.
You don't need a chart.
mearmi
05-02-2017, 12:40 PM
Thanks a lot
Barry97
10-06-2022, 04:37 PM
36509
This one is new to me. where do you get that print out.
