View Full Version : Can't make web connection with bizhub 600
Zahid khan
04-30-2017, 04:29 AM
I have connected bizhub 600 directly with pic via Ethernet cable.i put the IP address in browser but nothing happens.to find the ip of bizhub I go to utility...administrator setting....network settings...
tcp/ip setting .....
rudysemira
04-30-2017, 06:24 AM
You mean directly to PC from your machine. If you set static ip address to your copier then from pc, you need manually assign too., Go to local area connection then tcp/IPv4 set assign ip address manually if you are giving to the machine 192.168.100.10 then from pc should be 192.168.100.11.........try to ping.. Good luck
Zahid khan
04-30-2017, 08:18 AM
I tried that but no luck
rudysemira
04-30-2017, 09:41 AM
CAN YOU POST SCREENSHOT
Zahid khan
04-30-2017, 12:15 PM
CAN YOU POST SCREENSHOThere are the screen shots
blackcat4866
04-30-2017, 02:02 PM
Does it have the IC-202 Print Controller option? Base models cannot print. =^..^=
copier addict
04-30-2017, 04:13 PM
Pretty sure the network screen would not be available on the display if the print controller was not installed.
Zahid khan
04-30-2017, 05:18 PM
I checked printer controller is not installed .can I scan to pc without printer controller
blackcat4866
04-30-2017, 07:44 PM
Sorry, not true.
Nope. You need the IC-202 for scanning. Maybe you could do some of this research yourself, like Google? That's how I found out: http://www.copycom.eu/storage/app/media/docs/km-bh-750.pdf
Synthohol
04-30-2017, 09:58 PM
IIRC you can update the firmware with the standard network port but nothing else.
copyman
05-01-2017, 12:33 PM
I thought the Biz 600/750 came with scanning but not printing? Or maybe it is the Biz 601/751 with scanning included and not needing print controller chip?
