View Full Version : Bizhub 600
Syed Naseem
04-30-2017, 04:45 PM
Hello everyone..
I have a bizhub 600 which show paper jamming J-3206.
I will check completely but nothing paper anywhere.
I replace complete ADU unit but still issue same.
Have any friend idea how to resolve this issue.
Synthohol
04-30-2017, 10:28 PM
its the exit sensor turning on during idle.
not an ADU issue.
http://www.copytechnet.com/forums/attachment.php?attachmentid=36517&d=1493587626
Syed Naseem
04-30-2017, 11:11 PM
not an ADU issue.
I replace the exit sensor too..
But problem still same.
Woxner
05-01-2017, 02:56 AM
take the left end cover off and remove the exit assembly. paper maybe stuck in there and the mylar could be bent . could also be adu pwb
Synthohol
05-01-2017, 04:03 AM
yeah, give that actuator an extra spring wrap if you can.
sensor check 24-2 is the exit sensor PS37
1. "Service Mode screen"
Press the [State Confirmation] key.
2. "State Confirmation screen"
Press the [Sensor Check] key.
3. "Sensor Check screen"
Enter the check code and the multi code with the sheet number setting button.
The condition (H/L) of the sensor appears.
4. When conducting other sensor checks, repeat Step 3.
5. Press the [OK] key.
State Confirmation screen appears.
Syed Naseem
05-02-2017, 01:00 AM
I replace exit unit too...
Still same situation...... :confused:
Synthohol
05-02-2017, 04:29 AM
i'd try to reflash firmware then
trace the exit wire back to the prcb and check for a pinched or chafed wire along the way.
