View Full Version : tcr iu c and y problam
saeidss
05-12-2017, 01:24 PM
Hello friends
I have two images c452 series in the novelty of years ago I bought
I threw the device
Density 12 reding and y 4 density
help me tanks alot
Phil B.
05-12-2017, 02:10 PM
WOW we have had some threads that gave very little info as to the problem.. but you Sir have given the least that I remember..
what is the problem...
do you have printouts you can share showing it?
what have you done?
life of consumables?
help us help you
saeidss
05-12-2017, 03:19 PM
whyyyyyyyyy
help
Phil B.
05-12-2017, 09:39 PM
whyyyyyyyyy
help
WHY? what the questions?
do you go to the Doctor and say " it hurts" but give no further info than that?
are you a tech or an owner?
you want help but do not supply info...
done maybe someone will help.. even the title of your post makes no sense
Synthohol
05-12-2017, 11:04 PM
i understand a language barrier but his posts sound like a stroke victim.
it's a c452, put it out of its misery already!!
konica7022
05-13-2017, 10:39 AM
Mind you there are parts of the world where c452'z are still worshiped
saeidss
05-27-2017, 04:04 PM
hi stock image tcr level 12 and 17
habik
05-27-2017, 08:18 PM
Pull all IU's out of machine and give it a good shake. Then put them back in. If it doesn't cure then do Image Stabilisation Background Reset and Stablisation. Then Stabilisation + Gradation adjust. Do for each mode at least 3 rounds. Good luck.
I usualy keep TCR to zero!
Gradation Adjustments with Highlights below 60 and Halftones closest to 0.
saeidss
06-15-2017, 08:17 AM
not work
why
saeidss
06-15-2017, 08:27 AM
what have you done?
help us help you
hello
My two friends had one machine broke down.
I got this andakhtm corrupted iu this device one device and this problem before the prologue
The friends do not have chip images
Now I don't know what to do?
Sorry English is not good
tnx
copier addict
06-15-2017, 02:17 PM
hello
tnx
Type it in your own language and we can try to translate it. I have read the entire thread and still don't know what the problem is.
