View Full Version : Kyocera 8001 jam 4913 4915 4918
nathicana
05-24-2017, 12:58 AM
This Kyocera 8001 has jam codes 4913 4915 4918 bridge conveying sensor 1 not turning off.
Paper stops just entering the fuser, rolled up at finisher entrance, at primary feed and in conveying unit. Nothing in bridge area.
Replaced drawer of bridge section and the drive unit behind the drawer which has BRCS1 and BRCS2 sensors.
Problem is very intermittent, can happen single or two sided. Machine has 1.5 million copies.
The firmware is up to date, fuser recently replaced. Has anyone had 49xx codes on the 6500/6501/8000/8001 type machines?
blackcat4866
05-24-2017, 01:32 AM
Oh yeah, I've been down that road. Take a look at the exit sensor flag. At 1.5M you'll have a very noticeable flat spot on the top surface of the flag.
I went down that same road. I replaced the bridge sensors, flags, rollers, bushings, one-way bearings ... and none of it made any difference. Do I have a photo?:
36681366823668336684
Hi
While your taking care of the bridge unit issues, check the de curler flag and sensor...The sensor tends to get knocked out of place and a new style flag was released. The flag shaft is slightly shorter to allow a e/c clip to be used to hold it in place. Not sure of ser # cutoff.
Have fun
nathicana
05-24-2017, 05:24 PM
Thank you so much for the prompt reply.
This looks like middle guide from the exit unit just after the fixing area 302K994662. We will replace.
I wanted to make sure it wasn't the relay exit unit at left end of the machine.
blackcat4866
05-24-2017, 08:01 PM
That will do the trick.
Usually I just order the flag (302K928121) and return spring (302K928190).
The photo is of a short term MacGuyver that got the machine running until the part came in. =^..^=
tmaged
05-25-2017, 01:18 AM
The one with the paper clip was sheer brilliance !
blackcat4866
05-25-2017, 02:09 AM
Thanks. AFAIK that one is still in the field passing paper:
36690
If you work on Lexmark you'll understand my inspiration. =^..^=
habik
05-31-2017, 12:41 AM
36690
Quality BC.
I am using mylars on both sides. They seem to do trick plus its self adhesive so it is sometimes quicker, like in the drum area of finisher. ;)
nathicana
05-31-2017, 04:21 PM
36737Thanks for the help in getting this machine running!
36690
Hi Blackcat
The universal multi-use paperclip is a fantastic idea ...I used it yesterday, and to secure it to the flag I used instant light activated super glue 5 Second Fix As Seen On TV UV Gluel Light Repair Tool Liquid Plastic Weld Pen | eBay (http://www.ebay.com/itm/like/192120013444) . This seems to work well and the advantage is you can hold something in place and instantly bond it.
blackcat4866
01-30-2018, 11:53 PM
I'm glad it worked for you. It's acronym on the paperwork is SPC or LPC depending on the size of the clip. =^..^=
blackcat4866
02-01-2018, 12:11 AM
Hi Blackcat
I have a bunch of these (Lazer Bond 3 Second Fix - UV Light Repair Tool Liquid Plastic Weld Quick Welder | eBay (https://www.ebay.com/itm/Lazer-Bond-3-Second-Fix-UV-Light-Repair-Tool-Liquid-Plastic-Weld-Quick-Welder/263396989762?_trkparms=aid%3D222007%26algo%3DSIM.M BE%26ao%3D1%26asc%3D20150313114020%26meid%3D424819 ac08d643c6b22efe622bf95b8d%26pid%3D100338%26rk%3D1 6%26rkt%3D30%26sd%3D192120013444%26itm%3D263396989 762&_trksid=p2141725.c100338.m3726)that) I was quite disappointed with. it seems to adhere at first, instantly, but later on just falls off. I'll have to try the one you mentioned.
Overall I've had much better results with house brand 5 minute epoxy.
I use the UV just to set the broken piece/part in place , then follow up with the 5 minute epoxy and if appropriate , LPC or SPC whole or piece beaded in the epoxy for reinforcement.
Tonerbreath
10-30-2019, 07:33 PM
=^..^= Thanks for the post. Flag was worn just as you said. Picture tells the story
blackcat4866
10-31-2019, 01:09 AM
I'm glad it worked for you. =^..^=
