View Full Version : Error code sc52-07 0n 7085??
excanonguy
08-18-2008, 01:34 PM
The other tech I work with was unable to clear the code and is on holidays this week.....and I know almost nothing about this machine! It apparantly also had a sc29-04 code as well before this one came up, and thoughts opinions or suggestions greatly appreciated!!
Steve
Luther
08-18-2008, 04:20 PM
52-07 is main body cooling fan abnormality
excanonguy
08-18-2008, 07:53 PM
Does the fan usually die, or is it more likely to be a pwersupply or fuse issue? By the way the machine has over 4 million on it...Thanks!
Steve
You can never tell what will be the exact trouble but the most possible is the fan motor FM6.
excanonguy
08-19-2008, 12:52 PM
Great,thanks for your help I have got to go take a look at it today,its almost an hour and a half from our reg territory, so at least this will give me something to look for!
Steve
excanonguy
09-02-2008, 02:14 PM
Just wanted to post the follow up to this , I swapped the fans around and still got the same error ,so I could rule out the fan, so I started checking for power loss, and the 24VDC out put on power supply #2 was dead, a new power supply fixed the problem.
Steve
RockETop
09-03-2008, 03:36 AM
I just replaced a DCPS2. watch yer knuckles.
excanonguy
09-03-2008, 02:37 PM
LOL thanks for the warning,too late!!!
