View Full Version : How to connect FS 527 to C452
tsoft
06-05-2017, 01:26 PM
I bought used C452 and FS527. When I assemble them together, it looks like FS 527 is not recognized and has no power. any suggestion on how to troubleshoot this? Do I need to activate this somehow in a software?
mthomasebs
06-05-2017, 01:49 PM
Plug the relay unit into the finisher, plug the finisher into the unit. It should be recognised. No need for activation, If you've plugged it in correctly, then check the finisher board connections, under the back cover.
tsoft
06-14-2017, 11:19 AM
Thanks for the suggestion. I plugged everything in and it does not work. It does not look like finisher has power. Any fuses or other thinks to check?
copyman
06-14-2017, 12:52 PM
I've had the boards & finisher cables go bad a few times.
