View Full Version : Konica C224 series Auditron?
jonbonse
06-07-2017, 03:48 PM
Hi all
I have a client who needs an 'auditron' for their copier as they have people come into their shop to make copies.
Is there such a device for the Konica series of A3 colour machines?
mthomasebs
06-07-2017, 03:53 PM
Hi all
https://www.papercut.com/tour/embedded/konica-minolta/
jonbonse
06-07-2017, 04:07 PM
Thanks but i meant so the user at the till can press the auditron to allow the customer to start copying...
jonbonse
06-07-2017, 04:15 PM
They may be called 'Remote Copy Counters'
copier tech
06-07-2017, 05:48 PM
Emos make coin opp machines for copiers, is that any good?
EMOS Information Systems - Coin Boxes (http://www.emos.com/support/prodbranch.asp?branch=26)
copier addict
06-07-2017, 06:23 PM
Depending on the distance from the copier, all you would need is a card reader and just run the actual reader to the to the til and all the person behind the has to do is use the card to authenticate the copier.
allan
06-07-2017, 06:54 PM
You give card with loaded cash of the quantity required or even at a minimum quantity. Get one of those reader setups where you need to drop the card thru a slot.
50 cards should be good. Still going to need some licensing i guess.
oldschool
08-04-2017, 10:08 PM
Something like our True Count (https://www.jamexvending.com/series/true-count-remote-access-control) would work.
As long as Vendor II is supported by the copier.
Woxner
08-04-2017, 11:40 PM
vendor 2 is supported
Synthohol
08-05-2017, 12:11 AM
ACDI makes a great model ACD3000 that works beautiful.
one wire to the left side of the PRCB and 1 outlet for the brick.
