View Full Version : Dead Machine Konica Bizhub C451 No Power (Green and orange lit up on scanner but nothing else)
Doug James
06-13-2017, 02:27 PM
Been fighting this for awhile. The customer said this problem occurred after a power surge. I tested the power supply (bottom right of back of copier) according to the manual and it tested bad. Replaced with a known good power supply and still did the same thing. Have no idea where to go from here... Any help would be very appreciated....
Woxner
06-13-2017, 02:32 PM
MFP is shot
mo0651
06-13-2017, 02:49 PM
reseat/ replace memory chips.
Doug James
06-13-2017, 10:38 PM
reseat/ replace memory chips.I actually did that, was sure it would fix it...
afterhours
06-13-2017, 10:59 PM
Its definitely your mfp board. Your NIC and NVRAM are all in your mfp Replace it and you will be good.
Doug James
06-14-2017, 12:13 AM
Its definitely your mfp board. Your NIC and NVRAM are all in your mfp Replace it and you will be good.Sure do appreciate your help !!! Thanks so much !!!
