View Full Version : Miscellaneous Bizhub 454 and 454e
devontug
06-13-2017, 06:20 PM
Is there a way to remove the card reader authentication totally from my machine?
When I send a print it it says error deletion
36860
Synthohol
06-13-2017, 07:08 PM
Look in administrator settings then security settings turn everything off.
Check software switch 12 should be set to all zeros then hit fix.
devontug
06-13-2017, 07:09 PM
Will do that now and let you know
devontug
06-13-2017, 07:45 PM
When ever I send a print I'm getting error deletion
mthomasebs
06-14-2017, 08:51 AM
If using a card reader check Service Mode -> STOP, 9 -> Authentication Device2 -> Unset.
Check Utility -> Administrator Settings -> User Authentication/Account Track -> User Authentication -> either ON (MFP) or OFF. Switch to OFF.
Check Utility -> Administrator Settings -> User Authentication/Account Track -> Print without authetication > Restrict.
One of these should help.
devontug
06-14-2017, 03:09 PM
Got it to work thanks guys for all the help
