View Full Version : BHC 224 locked logo konica minolta
oscar
06-13-2017, 09:17 PM
I have a BH C224 that is locked on the Konica Minolta logo screen, does anyone have any suggestions? Does this work with the NVRAM reset works again?
copier tech
06-13-2017, 09:26 PM
You've probably tried this but first thing I would do is see if it will accept a firmware update USB.
oscar
06-13-2017, 09:32 PM
Does not accept..
The machine was normal after turning it off and on, she stayed that way.
habik
06-13-2017, 10:11 PM
Memory Dimms?
Woxner
06-13-2017, 10:37 PM
reset tool should only be used for board replacement and a few other things. it was not designed the way half the guys use it here. what bar is it hangging. that will tell you what might be wrong. did you try it with the hdd unplugged
avecosat
06-14-2017, 08:09 AM
If you can , try with other SSD in your machine .
