kola3f
06-16-2017, 04:25 PM
Hello all,
Bare with me but this will be a long explanation throughout my entire problem. I promise there will be a question at the end.
So I have a Konica Minolta Bizhub Press C1060. The Transfer Pressure Roller/Y broke in the Intermediate Unit. I didn't notice the problem while running a light colored job. When I finally did, I replaced it but I wasn't able to find the end piece of the roller that snapped off. It was the very tip of the roller and it was metal. I assumed that it fell all the way to the floor. I did find the washer right by the area where the yellow charging corona's wire grid ends which i guess makes sense since it's close to where the Transfer Pressure roller is. Ever since that time, I started having a problem with density unevenness with the yellow color. I did all the adjustments but still, in the middle of the developer unit, the developer was less dense then on the edges. I changed the developer. No improvement. I finally changed the developer unit and the yellow is ok. Now I have the same problem with the black, cyan and magenta. When I look at the developer units, the developer is dense on the edges but a lot less dense in the middle of the roller, causing my prints to come out very light in the middle of the sheet. All drums, coronas and developers were just changed. I believe that I have to change the developer units to eliminate the problem which I will be doing this weekend.
My question is this. I believe the developer units are still good. When I changed the developer and spun the roller, it evened out. The density was good throughout. But once installed, it started printing light in the middle. Is it a problem with the settings? Is there a way to disassemble the developer unit to see if there is some dirt in the middle of the restriction plate causing less developer to be applied to the middle of the roller? I saw somewhere that there is a way to manually adjust the density where I can add more density to the middle of the sheet. It's the "Density Unevenness Adj." but that adjustment is not visible in my options. Anyone know the code to unlock or show this adjustment.
I'll change the dev. units and hopefully my problems will be over but since the dev. units are only at 70%, I thought that they can be cleaned or readjusted. Is that so?
Thanks for the help.
Adrian
Adrian
