View Full Version : How can i reset the image unit on bizhub c364
javier4065
06-16-2017, 10:47 PM
Thanks ,maybe there is some parameter to cancel it .
Woxner
06-17-2017, 03:03 AM
these dont use image unit. they are set to let the drums run. replace the drum or drums which ever is bad and it will reset the counter.
HitMan
06-17-2017, 10:39 PM
This is an old post on here. If you follow the steps you can get the machine to run on beyond the life's of the units. The machine will run on fine but the consumable tab will say there's zero life, just tell the customer to ignore this.
To: KONICA MINOLTA AUTHORISED TECHNICAL PERSONNEL
TECHNICAL SUPPORT GROUP
Date: 20 April 2011
Topic: bizhub C652 (DS5)5 2\C4\C52\C360\C280\C220
IU end of life message can be disabled
Description
With the new version of FW G00-C2 and above it is possible to disable the end of life
message for consumables.
This will enable the service technician to manage the replacement of consumables
based on customer needs and expectation of quality.
Considerations
If you decide to remove the end of life message then please be aware that
performance of consumables operating past the specified life is not guaranteed.
This Includes copy\print quality, paper jamming and any other issues caused by
extending the lifetimes.
Konica Minolta UK except no responsibility for any problems that occur when
extending consumable lifetimes past the Life Specification.
Notes
1) All setting advised in this bulletin must be made at the same time.
2) Even though the end of life message has been removed, when the specified life
value is reached the oil can warning icon will still appear.
3) The notifications on PSWC, Fiery Control Screen and CS Remote Care do not
change and end of life message is still apparent (MIB information is not changed).
How to apply end of life settings
1) Upgrade the FW to Version G00-C2 .
2) Make unit change setting.
Service Mode > System 2 > Unit Change > Set Service for Imaging Unit.
3) Select No Stop for each consumable.
For Imaging Unit\Drum Unit\Developing Unit.
Service Mode > Enhanced Security Mode > IU Life stop setting > set to “no stop”
For Transfer Belt and Fusing Unit
Service Mode > System 2 > Software Switch Setting.
Change Switch No: 55
Bit 2 _ ON (Transfer Belt Unit ‘no stop’)
Bit 3 _ ON (Fusing Unit ‘no stop’)
HEX should read ‘0C’ when both switches are set.
4) Eliminate Life Message Display.
Change Switch No: 51
Bits 4,5,6,7 _ ON
HEX should read ‘F0’ when all these switches are set.
replace the chip on IU unit.
