View Full Version : Obtain Device Information Issue - Bizhub C287
gavrielx
06-22-2017, 08:34 AM
hi there,
Does anyone know what could be the reasons that sometimes the Obtain Device Information get error,
and then i need to set manually the Device Option?
tanks,
copier addict
06-22-2017, 09:21 AM
hi there,
tanks,
I find it is usually one of two reasons. 1. Wrong driver. 2. Wrong function version in the soft switches.
gavrielx
06-22-2017, 09:37 AM
can you please explain the "Wrong function version" what i have to check and where? and how can i fix it?
tanks,
emujo2
06-22-2017, 01:25 PM
On the MFP, select Menu/Utility/Device Information. On either page 1 or 2 you will see the current function version. The MFP and driver versions be paired correctly..
The latest firmware release is K7 (function ver 3.3). The matching drivers are 7.1.X.X. If you are at the correct driver/function version/firmware, then you have an issue elsewhere like SNMP settings, firewall, or antivirus blocking communication. Emujo
gavrielx
06-22-2017, 01:57 PM
tank you.
