View Full Version : konica 7040/7033 front door switch
LY3IJ
08-20-2008, 08:51 PM
whats the p/n ?
havent got the parts manual.....
:confused:
kmguy31
08-20-2008, 09:24 PM
55ga 1224 2
redime
08-20-2008, 10:39 PM
Why you need one? I usually have good luck with popping the thing open and cleaning all the contacts.
LY3IJ
08-21-2008, 06:34 AM
tried to open switch and broke plastic
sometimes it happens:(
redime
08-21-2008, 11:05 PM
Be gentle grasshopper
173545
08-22-2008, 12:03 PM
PN for switch is 40AA85010. Number given earlier is the actuator.
redime
08-22-2008, 10:06 PM
You sir are correct
glschfc
03-11-2013, 10:06 PM
I have a konica 7040 that I am trying to fix if the fix doesn't require calling in a technician. The display screen states "please wait front door is open". I have read the postings on this thread and attempted to clean any contacts. The only real interface appears to be a metal tab on the inside of the door that inserts into the counter when the door is closed.Any suggestions would be appreciateds. Please see attached photo.
Thank you
19864
Coptech
03-12-2013, 04:38 PM
7033 and 7040 are easy to get to the front door switch. Open the front door as you have and remove screws that hold the "paper clip tray" They go straight up. Lift that tray out and you are staring at the front door switch. My bet is that the plastic mounts are broken and it will require a new front inner cover. Those machines are pretty old and the plastic is pretty brittle by now. The later 7045 is a bit tougher to get to.
CraigW
03-15-2013, 04:12 PM
We had many that snapped the mounts off. Likely a bad switch w/message and they think slamming the door HARDER will get rid of it and snap.
We just replaced our last 7045 recently.... I really miss those machines. They were nice to work on in most cases.
