View Full Version : ta 6501i jamming
n25an
06-25-2017, 09:03 PM
I got a 6501i... customer complained its jammming...
I went in found rollers from tray 1 and 2 and high capacity tray worn down...
replaced them... got one jam... took all the paperfeed sections out and reseated... ran like a champ...
Customer called back... machine is jamming... cam back ran 400 pages on each tray... nothing... tray 1, tray 2 and high capacity...
jam codes are 511, 512, 533
message for codes multiple sheets fed in tray 1, 2, 3
error means feed sensor does not turn off during paper feed...
I have done rollers... firmware... and visual inspection... nothing blocking the path...
I am thinking its the paperfeed clutches or a solenoid if there is one there...
checking if I am barking up the wrong tree or if there is another direction that I need to think of...
blackcat4866
06-25-2017, 11:19 PM
Clutches. They will all look about the same: spilling rust dust everywhere
(8) 302KV44041
4 for lower desks #3/4
4 for trays #1/2
n25an
06-26-2017, 12:41 AM
sounds like you are talking about the clutches in the paper drive units
parts drive unit paperdeck 303NF94040
parts feed drive unit h 302N493030
also would you mess with the one way clutches on the paperfeed rollers,,,???
(8) 302KV44041
4 for trays #1/2
blackcat4866
06-26-2017, 01:12 AM
parts feed drive unit h 302N493030 ...
Yes.
... also would you mess with the one way clutches on the paper feed rollers,,,???
Probably not. I can't say that I've seen one of those Kyocera one-ways fail.
Only if the clutches didn't do it.
n25an
06-26-2017, 02:38 AM
thanks so much... just one more question... if I can beg your indulgence... in the service manual where it says you will see the stain when it fails what does that mean... is that referring to rust...???
Yes.
blackcat4866
06-26-2017, 06:09 PM
I haven't seen that particular notation, but yes that's plausible. =^..^=
n25an
06-27-2017, 09:19 AM
I updated the firmware again... and ordered the parts... hopefully that will fix it... thanks again...
n25an
06-29-2017, 03:46 AM
there are 9 clutches... 8 in the gearboxes... and 1 outside... that was fun... not...
Scottb
06-30-2017, 06:10 PM
It gets better after doing 10 or 15 ;)
Kidaver
07-03-2017, 07:38 PM
There is a black cover guide you have to remove on the paper feed units when replacing the feed rollers....lazy techs will not screw these back in or even put them back in and you will get jams and skewing all day long
n25an
07-05-2017, 10:46 AM
looks like it worked... thanks...
(8) 302KV44041
4 for trays #1/2
blackcat4866
07-05-2017, 01:10 PM
Cool! =^..^=
