View Full Version : C2060 with 300gr paper...
topimpress
07-12-2017, 05:40 PM
hi,
i have a new accuriopress c2060 and i have this problem when i print on 300gr width paper. on 130gr its normal.. any body know this prob
thx
copytechman
07-12-2017, 07:19 PM
hi,
thx
Dev units, check them for voiding, all of em
blackcat4866
07-13-2017, 01:27 AM
I think it's pretty obvious that it's the magenta developing unit. Yellow + magenta = red. =^..^=
copytechman
07-13-2017, 02:51 AM
I would agree, I had a c1060 do that exact symptom but it was the yellow Dev in that case on a pretty new piece of gear.
Regards!
A.
topimpress
07-14-2017, 04:39 PM
but why on 135gr the result is perfect...???
Phil-Davies
07-14-2017, 07:46 PM
Have you set the correct papeweight into the machine as the image looks unfused.
copytechman
07-14-2017, 10:56 PM
The machine uses different belt / Dev speeds based on weight. The heavier the stock, the slower the speed, at lower speeds the Dev doesn't fill the mag roller effectively if low on Dev.
Regards
