How can I reset the SSL certificates for a BizHub C203 from the console
  • sa43
    • Aug 2016
    • 6
    Hello
    We had to generate a ssl certificate in the printer on the webboard for papercut communication, something went wrong and the certificate, ie it looked like it did not finish creating, when the certificate was created it should display "if you want to add a certificate" By doing this on + 224e there was a problem, the certificate was created at the end when trying to connect by mozilla browser came up message whether you want to add a certificate - ok and went and works.
    I ran an old IE6 browser on an Xp window and did not. I ran Windows 98 with IE6 browser and there the certificate was added, the page tried to open for login but did not go by clicking F5 once there was an error message login to the web panel. I also did formatting the drive from the service level: logical and psychical
    In which place or at all it is possible to manually remove the ssl certificate in konica +203
    In this case I encountered for the first time, I was looking in the machine menu under the administrator to set the network / http server settings and ssl webDAV. I have two machines side by side the other is +353 compared in both menus and I have not found differences yet
    In the IP browser for web connection I now have the address https://192.168.0.180/, and I want to have: http://192.168.0.180/. The logon page does not show up to +203 at the moment, so it is not possible to make an https connection
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Re: How can I reset the SSL certificates for a BizHub C203 from the console
    Originally posted by sa43
    Hello
    There is a check box for use ssl/tls for http. It can be turned off in the web interface or in admin menu at the control panel.
    Another thing to try is type in http://192.168.0.180 in your browser and hold shift and press enter.
    Iirc formatting the drive deletes the certificates. They can be created in the web interface. I would reccommend seting the time the certificate to expire to the max.
    • vebaev
      • Nov 2019
      • 4
      Hi all,
      I have the same problem with my c203 - I tried to set up SSL https but something went probably wrong and now I do not have web access to the machine. I have searched in the machine admin panel how to turn off SSL or reset certificates or whatever.... but did not find any solution. Can anyone help? I really want to get again my web access
      • sa43
        • Aug 2016
        • 6
        Hi
        We did not find in the administrator menu as if there was such a function as is, for example, in C224e "Initialize". Only in the service menu is initialize what reset the ssl protocol. It works for C203 C253 C353
        Krystian K
        Poland
        • tsbservice
          Field tech
          • 7923
          Try this:
          -admin settings
          -system connection
          -open API settings
          -SSL - turn it Off
          • emujo2
            • Mar 2017
            • 1580
            Once you access the KM web page with SSL on, you sould get a message the 1st time saying something like are you sure you want to trust this self signed certificate..Varies from browser to browser..But, once you accept the warning, this SSL info is now cached on your browser..If you turn off SSL at the machine, the browser is still trying to connect via HTTPS. This does not happen if you disable SSL via the browser. If you run into this situation you have to either clear your browser cache, or use a different browser. You mentioned XP and some other ancient OS....this may be OK with a 203, but you would not want to try and communicate with newer devices. E
            • vebaev
              • Nov 2019
              • 4
              Originally posted by emujo2
              Once you access the KM web page with SSL on.....
              That's the problem I cannot connect, it says the connection is not private and it cannot open the web interface at all.....
              • vebaev
                • Nov 2019
                • 4
                Try this:
                -admin settings
                -system connection
                -open API settings
                -SSL - turn it Off
                It was OFF (tried ON and OFF again the same thing), still getting the page saying the connection is not private (below) and cant access web interface, strange....
                Your connection is not private
                10.26.0.40
                NET::ERR_CERT_INVALID
                • tsbservice
                  Field tech
                  • 7923
                  Have you try different browsers?
                  • vebaev
                    • Nov 2019
                    • 4
                    yes, firefox, safari, chrome...
                    • emujo2
                      • Mar 2017
                      • 1580
                      Try using IE in comptability mode..Looks like the certificate is using as older un aupported cypher. If this doesn't work, Service Mode, HDD format should clear any installed certificates, then clear the cache on your browser and try again. If you can get into Admin, try assigning a new IP address. This will nullify the certs as well. (try this before HDD format) E
