View Full Version : Error Code Bizhub C3850 - Doesnt recognize new toner
Konicatech
07-19-2017, 04:06 PM
Have a bizhub c3850 that after replacing the magenta toner it doesn't seem to recognize the cartridge... have tried several different cartridges and all the same results (please replace M toner)
have also tried replacing the magenta IU, and the part with the 4x contact readers that plugs directly into the PRCB, Getting nowhere fast with this one.
Any ideas?
Joe_tech
08-09-2019, 05:42 PM
Any ideas?
Did you ever find a solution? Thanks
mircea
08-14-2019, 06:50 AM
Any ideas?
hello you can try to update firmware and if that doesnt work you can try to check voltage on chip reader connector .
Best of luck!
Sysco
08-15-2019, 07:32 PM
1:The toner is not KM it's develop -> toner change
2:Check the other toner near by M -sometimes not correct the info in the display
3:Check the IU-s especially near by the M
