View Full Version : Konica 7075 warming up
bajetrini
08-24-2008, 04:39 PM
I have a konica 7075 that keep saying warming up all the time.
I have checked the connections on the fuser and the main body. I interchanged working fusers and the same problem, any ideas on what else to look for?
thanks
Bajetrini
laserman06
08-24-2008, 10:17 PM
thanks
Bajetrini
Check to make sure that the handle to the ADU drawer is latched completely. I have found that the handle gets stripped and looks like it is closed but is not. Follow the handle to the back and there is the lock/flag that actuates the ADU in sensor. Sometimes the screw comes out and it will not actuate. This causes the machine to say warming up.
I have seen this a few times.
Blessings,
Rob
Luther
08-25-2008, 01:52 PM
Also check the drum heater brushes ,the drum contacts these when you install the drum, remove the drum from the assembly and you will see them on the back side, hope this helps
Mark B
08-25-2008, 03:48 PM
check the fuser handel. By the way could you send to me the konica 7050 manual mbeitler@rtrbusinessproducts.com
Luther
08-25-2008, 03:51 PM
There is no fuser handle on a 7075,you must be thinking of the 7050,7155.7060 7065, not the 7075
Mark B
08-25-2008, 06:10 PM
I am thinking of a 7050.
Bizhub
08-25-2008, 06:41 PM
Check the drum heater contacts and check the fuser unit connectors.
It will be one of these .
Regards
bajetrini
08-25-2008, 09:03 PM
I tried all of these allready stil the same. I also used another drum unit from another printer and did the same thing so it must be in the drum unit section.
Haroldbfix
08-28-2008, 09:35 PM
The problem will be a dirty or bad TCSB, or shot developer.
