View Full Version : biz 250
erro 2557 appeared I replaced developer and it is ok but message "add toner" appears .
I cecked and noticed tat toner adding module doesn't work . No gear is turning.
Few days ago it was working. I cecked cables and are ok.
Any idea?
copyman
07-22-2017, 12:55 AM
There is a gear that breaks inside the sub hopper. Not a fun job to do. Easier to swap out the whole toner holder unit / hopper from a parts machine. If just buying parts to rebuild make sure parts are still available since this was deemed "end of life" a few yrs back.
Woxner
07-22-2017, 12:58 AM
you cant just replaced dev. you need to replace drum too. then reset counters turn machine off ck counters stayed 0. the run f8. . if you omly do dev and run f8 it will still code
copyman
07-22-2017, 03:21 AM
If I understood correctly the 2557 code is gone and now add toner message won't go out because btl not turning?
REGSIS
07-23-2017, 01:00 PM
Repair or replace 2 solenoids on toner hopper unit.
It is fun when you love jour job and know what to do!
REGSIS
07-23-2017, 01:04 PM
If drum is OK let's say 50k and developer depleted you CAN just replace developer. :cool:
